diffrens betwen 2wd engine with 204hp and 4x4 with 220hp
03-07-2006, 06:26 PM
can any one tell me the diffrent parts?
03-07-2006, 07:17 PM
Aggregate of everyones differences..
Head
Exhaust Manifold
Plenum
Throttle Body
ECU
Block
Pistons
Oil Pump
Water Pump
Thermostat Housing
Flywheel
Sump
Turbo Damper/Bracket
Cam Cover
03-07-2006, 10:19 PM
also the blocks different 4x4 has a 200 block witch is stronger than the 2wd 205 block
03-07-2006, 10:28 PM
03-07-2006, 10:40 PM
the managment is also more advanced...
03-07-2006, 11:35 PM
pistons are also different
04-07-2006, 07:32 AM
Quote:
Yeah.. the 4wd pistons have a larger volume dish.. the 3 door 2wd pistons have an offset gudgeon pin!
04-07-2006, 08:13 AM
Football Cwazy
also different oil pump/water pump/thermostat housing/flywheel.
04-07-2006, 09:53 AM
I thought the 4wd pistons had offset gudgeon pins ??
04-07-2006, 09:56 AM
both engines still break tho
04-07-2006, 09:59 AM
04-07-2006, 02:46 PM
04-07-2006, 03:28 PM
Live long and prosper!!
2wd have centre piston pin this is why u get slap
Ford then changed to the offset design in the 4x4's
Most race pistons have a centre pin due to high revving etc etc
04-07-2006, 05:28 PM
I thought so.
04-07-2006, 08:32 PM
04-07-2006, 08:35 PM
The 3 door 2wd engine has the offset pin.. the sapphire 2wd, 4wd and escort cosworth have a central pin..
04-07-2006, 09:02 PM
Quote:
Originally Posted by millsyscossie
Get out of dodge millsy it purrs like a kitten does my yb.
jason_nike
18-08-2019 10:53 AM
FlashRS
14-09-2015 12:36 PM
rog
04-09-2015 12:10 PM
MARKYMARKONE
20-08-2015 12:55 PM
Old ford
31-07-2015 06:50 AM
