what is this part called ??
22-04-2006, 01:16 AM
what is this part called? and who sell this ?? its for my cossie 4x4
22-04-2006, 06:13 PM
bump
22-04-2006, 06:23 PM
looks like somethig to do with the propshaft
22-04-2006, 06:53 PM
i think its the prop shaft rubber bush. ford should still sell them if not try the ford national clearance centre, you can order on line.
23-04-2006, 01:25 AM
i know were the part sits on the car , its after the gearbox .
its conected to the axel going back ,
23-04-2006, 01:32 PM
its the doughnut/center prop bearing
23-04-2006, 07:24 PM
Its called a Guibo joint and sits between the primary part of the prop and the gearbox on a 4x4 sierra
Ford only sell it complete with the front part of the prop for about £180 I believe
Find a decent breaker and he should be able to sell you a good one, they are the same on all MT75 4x4 Sierra not just cosworths
23-04-2006, 10:38 PM
thanks , ford ( norway ) say it cost about £120 for only the rubber .....
24-04-2006, 10:41 AM
be careful that the one on the left does not turn up instead of the one on the right ( thats the early xr4x4 version)- Ford UK would do not supply it as a seperate unit, but Ford Norway may be different.
good luck
28-04-2006, 06:03 PM
deflex do a poly bush part for this as a direct replacement i believe
29-04-2006, 05:11 AM
dont cut the metal clip off the new one till its fitted otherwise it wont go on
29-04-2006, 08:57 AM
Bushe
I wanted to get this new item for my 1990 4x4 saff, went to fords and apparently its not sold as a separate unit, had to buy a complete prop which totalled around £300, if you can just get the rubber in norway stay in touch might be asking you to send me one lol
C L
30-04-2006, 12:29 PM
I am breaking a Sierra and it has one of those items on it... Car is in good condition so I expect this will be good. What would you offer?
155lee
06-09-2016 11:10 AM
dirty-diesel
03-10-2015 08:00 PM
IainRS1700T
25-09-2015 06:44 AM
oilman
Trader Parts for Sale.
23-09-2015 07:32 PM
