NEW/UNUSED- Cat Cams Vernier Pulleys + SPA diginal Intercooler dual In/Out temp gauge
First up, the Cat Cams Pulleys, boxed and unfitted- £130 delivered- These are normally £220+ as they're pretty flash and look amazing. Here's the info...
Cat cams new range of True Lock Vernier pulleys offer a fresh approach to pulley design.
The series of holes in the inner and outer setcions of the pulley are arranged so that as the locking pin (shown) is moved from hole to hole, the pulley indexes exactly 1 Cam degree.
The central hole (Where the pin is in the picture) is the zero position, the holes allow up to +/- 10 degrees movement.
This allows fast accurate swinging of the cam timing when setting up on the Dyno/Rolling road therefore saving time & money.
When untertaking a dummy build of your engine the holes can easily be marked to indicate which holes are 'Valve Safe', the positive positioning giving more confidence when undertaking changes in cam timing.
The outer part of the pulley is 'Hard' Anodised which is much less suseptable to wear than other manufacturers decorative red/blue finishes therefore giving the pulley a greater lifespan.
And a final small but important design feature is the change to std Hex headed bolts that are less likely to 'Round Off' than allen key headed screws.
Pics...
Next up, the SPA digital Dual Intercooler (IN/OUT) gauge setup, again, with original box, and never actually fitted. £200 delivered. These are normally £280+ (£320+ direct from SPA!) as they're pretty flippin awesome.
Here's the info...
DG 224 Intercooler In and Intercooler Out Gauge
SPA’s Intercooler in/Intercooler out dual gauge represents one of the most accurate intercooler monitoring devices available. Monitoring two values simultaneously along with user programmable alarm conditions and peak recall of maximum values you can see the effectiveness of the vehicles intercooler as well as monitor critical temperatures with this device. The intercooler channels monitor temperatures to 255 deg C.
Kit is fully inclusive of all sensors, thermocouple adaptor boxes and wiring as well as comprehensive user manual.
Pics...
Pics...
Here's the info...
Pics...
Mark RS
12-10-2015 06:01 AM
