Ford Puma Discuss the Ford Puma here!
puma difficult to select gears
Old Jan 19, 2013 | 10:28 PM
benscab's Avatar
benscab
Default puma difficult to select gears
1999 puma 1.4 very hard to select any gears at all, stalls at traffic lights when trying to hold it on the clutch and seems to be crawling forward with the clutch depressed.......................PLEASE HELP.
Old Jan 19, 2013 | 10:50 PM
the_frozen_one's Avatar
the_frozen_one
Check the brake fluid level. Bleed the clutch.
Or adjust the clutch cable.
Depending on what you've got, don't know if a puma is hydraulic or not
Old Jan 19, 2013 | 11:34 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
there hydraulic Frozen
look for fluid/damp at the bottom of the gearbox/engine join
pump the clutch 5 or 6 times at a standstill, if it gets better it will be the hydraulic slave cylinder, if not a worn out drive plate, either way stick a 3 piece clutch kit in it when the box is out
Old Jan 20, 2013 | 09:29 AM
benscab's Avatar
benscab
thankyuo both i will try that today.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
mk3ste
Oct 17, 2021 10:09 AM
youngben
Sep 27, 2015 09:37 PM
Marv888
Sep 26, 2015 03:44 PM
