Puma brakes.. no pedal - done! brutal lol
#41
competant bodger
http://www.jhmbuttco.com/acatalog/Sh...eeders_37.html
mines very similar to the one that is 12th down on this link just that mine has the fluid bottle and pump etc all in one unit
#42
its an electric pump that sits in a bottle of brake fluid, it has a cap that fits airtight on the ressy then you fit a pipe from the unit with an airline type connection then just switch it on and it pumps the fluid in really simple thing really ive had it years i actually found it in a skip outside a garage lol, it didnt work at the time but only had a broken wire on it, ive never been able to find one for sale only similar ones online for about 400quid!!
interesting though, got any links to the £400 kits or a name so i can google it?
hope this info helps you fudge and hope you get the puma sorted ok
#45
oh thats a good idea, sounds like a good bit of kit and to get it for free is the icing on the cake. sorry
thanks for answering my questions anyway and i hope its helped fudgey too.
#48
Received 1,044 Likes
I dont know if it will work with the brake system but ive done it this way a few times to bleed clutches. I use a little oil can and put brake fluid in it then put a bit of pipe on the end and attach it to the nipple(when open) and pump the oil can trigger to force fluid back to the master cylinder. I dont know if this would cause the seals in the mc to turn though.
#49
There must have been a problem with the brakes before for them to be so crap so although you've fitted bigger discs and calipers the original problem is still there. Is the servo working as it should, does it get a rush of air when you remove the vacuum pipe? M/C's are pretty cheap, might be worth replacing for piece of mind?
#50
yes there was a problem with the original brakes, upon removing them i found that on both inner disc edges, about 1" all the way round was rusted off/missing, so the inner pads on both sides were only in contact with about half the disc face or less.
ill re bleed tomoz and report back lol, cheers for the tips lads
#54
07-10-2015 12:56 PM
