st220 oil leak help
st220 oil leak help
I have a small oil leak I cant trace, As far as I can see without pulling it all apart it seems to be coming from around the top of the aux belt area mainly where the powersteering pump is. I cant see for sure as its so tight and under an engine mount. Any ideas where the leak could be coming from?
Cheers in advance
Cheers in advance
It looks like it yes, although I guess it could be steering fluid. Is there anywhere on that part of the engine that could leak oil? As I really dont know. It doesn't help that none of the fluid levels are dropping so I cant say for sure what it is thats leaking
deathrider666
28-09-2015 06:12 PM
