Uneven Tickover
Old Oct 11, 2017 | 07:58 PM
savvy's Avatar
savvy
Default Uneven Tickover
Hi Folks.
Had a problem with uneven tick over when cold. Runs great when warm and returns 54 mpg, no smoke and gets regular services.
I changed the air filter again yesterday as a matter of course and decided to remove the top of said filter housing to clean it. I noticed that the clip that holds the rubber hose after the MAF sensor was missing. With my limited knowledge of said 130 TDCi I would have thought that this could have caused the uneven tick over? I have cable tied it at the moment until I can get a clip.
It does seem better today on a 75 mile motorway run, will keep an eye on it
Thoughts please!!
Old Oct 13, 2017 | 07:47 PM
I know these engines can suffer from poor idleing and hunting. Its normaly a faulty fuel sensor on the fuel pump. Its held on with 2 allen key bolts. Its a five minute job to change. But the poor idleing and hunting is normaly all the time no matter if the engine is warm or cold.
Old Oct 13, 2017 | 08:01 PM
savvy's Avatar
savvy
Many thanks Glenn. Could you please be more specific on the location of said sensor? Is it on the pump at the front l/h side of the engine looking from the front of the car, behind the EGR pipe
One of these? Delphi Inlet Metering Valve IMV Fuel Pressure Regulator Sensor 9109-903 from fleabay.
Forgot it's mk3 mondy 2007, last of the mk3 TDCi
Barrie
Old Oct 14, 2017 | 06:24 PM
These are the ones ive changed in the past. They just bolt to the back of the fuel pump. I think its ran off the cam shaft.
http://www.ebay.co.uk/itm/FORD-FUEL-...oAAOSwAuZX4QL~
Old Oct 14, 2017 | 06:27 PM
Are these the same as a mondeo??
https://www.google.co.uk/search?q=fo...W4Z29zlJ8j2mM:
Old Oct 14, 2017 | 06:28 PM
Its the switch with the clear plug.
Old Oct 14, 2017 | 07:10 PM
savvy's Avatar
savvy
Many thanks, will have to get dirty now.
Cheers for the info
Barrie
