Mondeo Mk3 Sweeping Dials
Old 08-03-2013 | 08:33 AM
nrico2006's Avatar
nrico2006
Default Mondeo Mk3 Sweeping Dials
Hi,
Recently left my car in for a general service and when I picked it up I noticed that upon turning the ignition on, the dials on the dash all sweep around to the max and come back down to the start again. Also, the trip computer's information is reset (temp in FH, miles in KM, average miles etc reset). The clock is also not working. The car is turning over fine, never had any hesitation with starting the car.
I had this problem before and simply replace the fuse for the clock and everything worked fine, but this time it is not solving it. Is their anything that would have been performed in a service that could cause this?
Thanks for any help.
Old 08-03-2013 | 08:40 AM
STeve's Avatar
Moderator
quite normal if service lights have been reset or if battery has been disconnected
Old 08-03-2013 | 09:15 AM
nrico2006's Avatar
nrico2006
Thanks for your reply. My radio is working fine and didn't need a code entered. Would the radio not have needed the key code entered if the battery was disconnected?
Old 08-03-2013 | 09:47 AM
dojj's Avatar
dojj
Resident Wrestling Legend
It does this is there is no power to the dials
Is there a fuse for constant power for memory etc that may have blown?
Old 08-03-2013 | 12:38 PM
STeve's Avatar
Moderator
if it does it all the time dojj is correct as its like losing the memory on your stereo so its reboots every time, but if it was just a one off then its nothing,
Old 08-03-2013 | 01:06 PM
martysmartie's Avatar
martysmartie
This is usually a sign of a bad battery, as the voltage drops below what it should when cranking.
Martin
Old 08-03-2013 | 02:38 PM
dojj's Avatar
dojj
Turn the ignition on
If the dials sweep you have had an interrupted power issue
If you then turn the ignition if and on again does it do it again?
Make sure you turn the ignition full off rather than just position one
mk3ste
17-10-2021 10:09 AM
wowk
30-03-2021 07:49 PM
07-10-2015 12:56 PM
Brickhouse
14
03-10-2015 07:28 PM
Steve Escos
01-10-2015 06:57 AM
Quick Reply: Mondeo Mk3 Sweeping Dials
