Brembo brake caliper fitting
What part do i need here .
I bought all the kit
Brembo calipers.
Brackets to fit focus rs calipers to a st24 brackets
Focus RS discs.
The holes in the calipers seem to going the wrong way.
Ok i have seen a pic of a carrier.
Any eone a part number.
I suppose ill go to Ford (dread)
BREMBO P.N. 80.040
I found the part i need and there quite cheep
BREMBO P.N. 80.040
Brembo calipers.
Focus RS discs.
BREMBO P.N. 80.040
BREMBO P.N. 80.040
brembo mounting brackets 130mm
i need a set of these 130mm between the stud centres and either 130mm holes like these and then use my conversion bracket.
Or straight into a 3 1/2 " hole senario.
This means they will bolt straight onto my st24 then.
Is there anyeone making these.
jason_nike
18-08-2019 10:53 AM
Wilsfoci
15
30-03-2016 10:26 PM
track.focus'd
12-08-2015 05:53 PM
