XR2 racecar with ST170 engine poss build
I'm thinking of building an XR2 racecar with St170 engine and Jenvey throttle body set up and Omex ECU.
What is needed to sucessfuly fit the ST170 engine into the Mk2 Fiesta, I know I need to change flywheel to CVH and sump for a 1.8 Zetec Escort or Fiesta item.
Will be run on BC gearbox
Any info or ideas would be greatly appreciated
CHEERS!!
CHEERS!!
No need to change the sump on the ST170 as its already the right way.
You need to spin the water pump the opposite way though. There are brackets available from area6 that do this off the shelf.
The flywheel can be 1.6/1.8 zetec or a efi CVH if you have one. If fitting CVH the mounting holes need drilling to 11mm which is 0.5mm bigger than normal.
The engine mount needs sorting just the same as any zetec but thats not a problem.
HTH
Mart
HTH
Mart
jessie_rs
11
03-06-2019 04:57 PM
Ben26
27-08-2015 08:56 PM
track.focus'd
12-08-2015 05:53 PM
