Ford Focus ST225 (MK2) 2005-2010 Everything relating to the Mk2 ST225 preface & facelift versions from 2005 to 2010
focus st225 esp fault???
Old 24-01-2014, 09:38 PM
richierich1986
richierich1986's Avatar
Default focus st225 esp fault???
Hi all,
driving along earlier light acceleration suddenly a noise as if the abs is kicking in then it comes up with esp system fault then engine system fault comes up putting my car into limp mode and also causing my car to misfire sounding like a subaru this has baffled me any help would be appreciated thank you.
Old 25-01-2014, 07:34 AM
oldford
oldford's Avatar
Get the codes read from engine and ABS.
That needs to be done with Ford specific equipment, because generic EOBD/OBD2 cannot communicate with the ABS system.
Old 25-01-2014, 07:41 AM
RichieST
RichieST's Avatar
Air flow meter fooked possibly. Common fault on them and it will show esp error when it fails. But as said, get the codes read!
Old 25-01-2014, 11:40 AM
richierich1986
Cheers for that put it on the computer today turns out it was the air mass meter very strange that it would bring on the esp light as well but the new air mass fitted it seems to be ok now. seems to go abit better than before the fault is this possible?
Old 25-01-2014, 11:50 AM
oldford
oldford's Avatar
Yes, it certainly will feel better if the airmass meter was defective.
Modern computers om a car share information. The engine will share rpm, load and those kind of things with the ESP/ABS, the automatic gearbox and others. The ESP needs that info to calculate how to counter act when wheel spin occurs. Engine load can be calculated from the amount of air going into the engine, so a defective airmass meter can bring up the ESP light.
oilman
Trader Parts for Sale.
23-09-2015 07:32 PM
DixieTheKid
14-09-2015 09:04 PM
NC53
13-09-2015 03:05 PM
natehall
Ford Focus (All Models)
08-09-2015 05:13 AM
Quick Reply: focus st225 esp fault???
