ST170 gear linkage help
Old Mar 3, 2014 | 09:29 PM
The Loumiester's Avatar
The Loumiester
ford whore
Exclamation ST170 gear linkage help
The gear linkage on my ST170 keeps popping off the gearbox, iv previously zip tied it but the rubber part that goes on the ball joint has worn too much to the point where it wont entertain a gear change without coming off at all.
Can I replace just this end peice (if so where can I get it as I cant find anything) or is it the whole linkage that comes a complete unit, can I get a brand new one as no where seems to have these other than second hand.
Any help would be much apreciated.
Louis
Old Mar 3, 2014 | 09:36 PM
GVK.'s Avatar
GVK.
New cables required unless you can find the bits second hand.
Old Mar 3, 2014 | 10:04 PM
The Loumiester
ford whore
Do you know the best place to get the cables? No parts store (e.g eurocarparts) does them from what iv checked.
Old Mar 3, 2014 | 10:43 PM
GVK.'s Avatar
GVK.
Be gen Ford only as unique to the ST170.
Old Mar 4, 2014 | 01:37 PM
The Loumiester
ford whore
Iv rung Ford and the guy found the part on his computer but didnt have any because they dont make them anymore.
He gave me the part number to help me search for one which is 4593550 but I cant find one, looks like myonly option is to buy used and hope the rubber bush is in good condition.
Old Mar 4, 2014 | 02:07 PM
jam53ice's Avatar
jam53ice
Ford don't do the cable ends?!
My 2.0 focus using the MTX-75 gearbox had the same problem and the garage I used called up Ford and got the cable end, only cost Ł30
Old Mar 12, 2014 | 11:51 AM
The Loumiester
ford whore
Does any of you know of any other substiyute cable ends?
Old Mar 22, 2014 | 10:29 PM
The Loumiester
ford whore
Has no one on here manage to deal with this issue? I dont realy want to risk a second hand one in case it has the same issue.
Old Mar 22, 2014 | 10:41 PM
RichieST's Avatar
RichieST
Send a parts request to fordpartsUK.com as they hold a lot of new old stock items.
Old Mar 31, 2014 | 03:09 PM
The Loumiester
ford whore
Right iv aquired a used item off ebay but havent fitted it yet, seems to be a different end to it whete it attaches to the gear box, it has a button on both cables to release it ftom the ball, the one currently fitted is just a rubber bush to keep it on, do any of you know if there where any design improves in later models of ST170?
Old Apr 3, 2014 | 07:39 PM
motosam68's Avatar
motosam68
Angry st170
just had new cam belt fitted picked car up and took home but no power felt like air filter was block up !!! drove it today still no power any ideas
Old Apr 3, 2014 | 09:24 PM
The Loumiester
ford whore
Is this engine management light on?
Old Jul 7, 2014 | 10:06 AM
The Loumiester
ford whore
For any one that wishes to no as its quite a common problem but it doesnt say this anywhere on the internet, there are 2 designs of gear linkage, the one on my 2002 ST170 used a rubber bush design to clip on to the gearbox which after time as with any bush the rubber perishes whereas the replacement I got I can only assume was off a newer ST170 which has a plastic design with a push button to clip on/off and seems a hell of alot better.
So if any of you ever have this issue then know that there is a revised linkage worth changing to.
Old May 1, 2015 | 08:19 PM
anth tnt's Avatar
anth tnt
Hi I'm having the same trouble with mine. Can I ask where you got the part from? . My problem is the bushes on the part which is attached to gear box. I have been told by ford parts that this can only be sold with the full box. Can you help.
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
The Youth.
Sep 30, 2015 09:59 PM
Sp3no
Sep 27, 2015 07:23 PM
Marv888
Sep 26, 2015 03:44 PM
