Bonnet won't release
Old Sep 14, 2013 | 08:20 PM
marceatspies's Avatar
marceatspies
Default Bonnet won't release
Hi guys I need some help - I've got a focus st-3 but the bonnet won't release, anybody got any ideas on how to get it up? Thanks in advance
Old Sep 14, 2013 | 10:37 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
Have a look at this mate:
http://www.focusstoc.com/forums/topi...net-wont-open/
You may have to register first though, not too sure.
Old Sep 15, 2013 | 05:14 AM
marceatspies
Cheers mate
Old Sep 15, 2013 | 08:50 AM
St3V3_C's Avatar
St3V3_C
Sorry
Old Sep 15, 2013 | 09:04 AM
dojj's Avatar
dojj
Resident Wrestling Legend
Do you need to key the bonnet open? In which case its out with the drill to remove the bolts in the bonnet lock
You won't see the mess behind the grille afterwards
Old Sep 16, 2013 | 07:57 AM
vaughant's Avatar
vaughant
Not sure if their the same as a mondeo mk3 but you can squeeze a 10 mm ratchet spanner behind and undo them,real fiddle though.
Old Sep 16, 2013 | 08:04 AM
BigErn's Avatar
BigErn
Cables stretch with the heat, once you get it open make sure you change the cable or you will have the same issue every time. Think you get the barrel and cable assembly from ford for about £40 but it will need tumbling to fit your key.
Old Sep 16, 2013 | 08:59 AM
Brendan's Avatar
Brendan
struggling with reality
the focus opens with a key...... Are you using the the correct key? (valet key will not work so I am told or give access to the boot)
Old Sep 16, 2013 | 06:09 PM
scoobykilla123's Avatar
scoobykilla123
Mine 07 plate has this issue, the cable from the key hole to the latch is broke. It goes into a like male to female connector you will find that has broke off. I now open mine with a long screwdriver after removing the cable. Get you arm right up grab the cable and yank it down only way to get it open unless you destroy your grill.
scoobykilla123
It's the ignition key that does the bonnet lock which I'm sure he knows lol
dojj
Sep 29, 2015 10:32 PM
jay030787
Sep 18, 2015 04:38 PM
Flatlinedan
Sep 18, 2015 12:41 PM
Jerry Ryan
Sep 2, 2015 08:02 PM
