Pipe Collapsing on ST170
Old Mar 26, 2012 | 02:24 PM
danme1987's Avatar
danme1987
Default Pipe Collapsing on ST170
This pipe comes from the throttle body and goes down behind the engine somewhere around the gearbox area which i cant reach. When i put the throttle on it collapses. So i know i need to get it replaced but doesn anyone know what its for?
thanks
Old Mar 26, 2012 | 02:28 PM
duncans90's Avatar
duncans90
Got any pictures of it mate as i have an st myself
Old Mar 26, 2012 | 03:14 PM
danme1987's Avatar
danme1987
This is the pipe and its located here in the engine bay. I should have said its an ST170 not ST2 etc
It collapses just where the arrow is pointing
Any idea would be great
Old Mar 26, 2012 | 04:10 PM
andi-p's Avatar
andi-p
I have had a few 2.0 focus that have had a pipe go at the back and it caused erratic tickover. When I removed the pipe it seemed to be a crank breather and the build up of oil over time had rotted the pipe. Hope this helps.
Old Mar 26, 2012 | 09:00 PM
danme1987's Avatar
danme1987
does that mean its buggered or it just needs a clean?
Old Mar 26, 2012 | 09:04 PM
andi-p's Avatar
andi-p
They go soft and deform easily. Possibly better changing it
Old Mar 26, 2012 | 09:10 PM
danme1987's Avatar
danme1987
Dont suppose you know what its called so i can ask ford? thanks
Old Mar 26, 2012 | 09:16 PM
andi-p's Avatar
andi-p
The parts dept will probably know what it is as they are a common problem. Hope this helps.
Old Mar 26, 2012 | 09:39 PM
danme1987's Avatar
danme1987
cheers mate. ill be giving them a ring tomorrow
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
stephenb4506
33
Oct 2, 2015 06:25 PM
mpilk
Sep 27, 2015 09:21 AM
