st170 imrc p1518 sticking manifold flaps
Old 27-01-2012, 07:52 PM
  #41
skypeller
skypeller's Avatar
Thats precisely all i did....aswel
Sometimes people look for problems which turn out to be nothing but dirt or grime/corrosion like my bmw which had a faulty wiper switch and brakelight cuircuit failure which i repaired with wd40 on the contacts
Old 27-01-2012, 08:12 PM
  #42
Coca
Coca's Avatar
Originally Posted by danme1987
So you simply put some wd40 in and it worked? Seem lucky if thats all you did
Yep, that's all I could do. I couldn't get the motherboard off as the screw that is in the hole wouldn't budge. I just sprayed it and then tested. It worked so I put it all back together. Lets see how long it lasts.
Old 07-02-2012, 07:47 PM
  #43
Coca
Coca's Avatar
Update: It has been over a 10 days and I have covered about 150 miles.The EML hasn't come back on and the car is running much smoother. There was a slight bogging down low down the revs when the flap was sticking. It has gone now. Hope it lasts
Old 07-02-2012, 08:42 PM
  #44
skypeller
skypeller's Avatar
3weeks 700miles..... No light fingers crossed
Old 09-02-2012, 07:14 PM
  #45
Coca
Coca's Avatar
Have you noticed a difference in MPG?
Old 09-02-2012, 07:43 PM
  #46
skypeller
skypeller's Avatar
My mpg has always been good since i picked it up from previous owner in new year holidays....the dsi was always working but light got sent on from it sticking very occasionally i think
Old 14-02-2012, 11:31 AM
  #47
discos7u
discos7u's Avatar
Hi all
First post - be gentle!
Like many Im having problem with my IMRC. I have picked up a spare from a car which was breaking - my plan is to refurb this one and then swap with the one on my car.
Can anyone tell me which route the IMRC cable takes from the box to the DSI clip? What else do I need to remove (other than airbox) in order to snake the cable around/under where ever it goes?
Thank you!
Old 17-02-2012, 02:21 PM
  #48
discos7u
discos7u's Avatar
Originally Posted by discos7u
Hi all
Thank you!
Bump!
Can anyone help me out with the route of the IMRC cable?
Old 17-02-2012, 02:35 PM
  #49
Coca
Coca's Avatar
I never actually took the whole thing out of the car. I just unscrewed the imrc box from the bulkhead and opened it up and wd40'ed it.
Old 17-02-2012, 02:39 PM
  #50
discos7u
discos7u's Avatar
OK thanks
If I cant see where the cable is router think I'll do the same...
Old 17-02-2012, 03:18 PM
  #51
skypeller
skypeller's Avatar
Yeh it looks like a pain in the a:Ł28;7322;82&3!!!! So i just unbolted imrc and wriggled it sp that i could work on it near the fusebox/batt area
Old 22-02-2012, 09:12 PM
  #52
ThePoons
St170
ThePoons's Avatar
the cable just runs under the air box thats all you need to take out.
Right so you reccon that if i spray this little box of magic with wd40 it will work. ive had this box off so many times trying to avoid the Ł190+vat from fords for a new one. ive already re-soldered the connections on the motherboard inside and that did turn the light out for 2 months over a thousand miles... ill do the wd40 trick tomorrow and let you lot know how i get on.
Old 23-02-2012, 06:05 PM
  #53
ThePoons
St170
ThePoons's Avatar
Took it apart today and sprayed some wd40 in there and re soldered the main connections. Turned the light out with the scanner. Done 15 miles so far see how it goes.
Old 01-03-2012, 05:59 PM
  #54
rallybertie
rallybertie's Avatar
Hi guys, I would like to add to this thread because I have recently had my Management light come on to be told is was the Runner staying open.
However once I stripped out parts I could see that the DSI cam had come off the end of the runner shaft.
I repositioned it and thought how was it fixed in place! today I went out and the light came on again, I looked at the cam to only find it come off completely this time and therefore the return spring has now gone missing.
I visited my local Ford Dealer, Vospers in Plymouth and have now ordered a new came and a clip, which was missing and the reason why it came off in the first place.
Does any one know if a new spring comes with the came / clip, if not where can I get one?
Old 01-03-2012, 06:05 PM
  #55
rallybertie
Default Missing DSI return Spring
Hi Guys, I recent had the Management light come on. I was told it was the 'Inlet Manifold Runner Staying Open'.
Upon investigation I found that the Runner Cam had come off the runner shaft.
I managed to repostion it and load up the spring to open the runner when the cable doesn't pull on it, but did think how was it kep in position.
That was yesterday, today I went out and the light came back on, I had a look at the cam to find it had come of, but the return spring had been lost now.
Upon looking at these threads I have discovered that it is a star washer that goes over the shaft.
I have now ordered a new cam and spring from my local Dealer, Vospers in Plymouth, but they couldn't tell me if the return spring came with it.
Does any one know if it does, if not, where can I get one?
Old 18-12-2012, 05:18 PM
  #56
AJ_ST170
Lol was a Virgin
AJ_ST170's Avatar
Post Similiar issue
Hi Guys
With my ST the unit stopped working due to the plastic gear inside the IMRC being broken and the management light staying on.
I stripped IMRC unit and rebuilt up that plastic Gear due to the fact that Spares are rare on this side of the planet. After a few months it broke again and i just fixed the unit of open and use the car everyday.
It seems to be fine, does anyone know if this could have a negative performance affect?
I would prefer to upgrade then repair and I am considering the aftermarket metal unit or ITB's .
I need power guys and lots of it!!!!
Old 18-12-2012, 07:07 PM
  #57
PaulinhoT
PaulinhoT's Avatar
Is there an actual way of running the ST170 without the system ?
Old 27-12-2012, 06:44 PM
  #58
AJ_ST170
Lol was a Virgin
AJ_ST170's Avatar
Old 11-01-2013, 08:40 PM
  #59
Fraserb
Fraserb's Avatar
Mines flagged this up today, when I turn the ignition to pos 2 I can here the IMRC clicking away so hopefully it can be fixed using this method. I'll have a squint at it tomorrow
Old 15-01-2013, 11:26 AM
  #60
AJ_ST170
Lol was a Virgin
AJ_ST170's Avatar
Hi Fraserb
You have to strip the complete intake manifold to get to the unit
Remove the IMRC unit from the fire wall with the attached cable
Open the box up, carefully as it is factory sealed
Repair the gear and you should be fine for a temp repair and it will save you cost
But as i said, i jammed the gear open on the manifold on mine
Best of luck
Old 15-01-2013, 01:01 PM
  #61
Fraserb
Fraserb's Avatar
Originally Posted by AJ_ST170
Hi Fraserb
Best of luck
You don't need to strip the intake manifold mate to get it out. You unbolt it from the bulkhead and it can be manoeuvred over onto the battery try to be worked on. What had happened with mine was that the return spring had jumped off the cam inside the unit. Turn gear to get it back into the correct position, a wee bit chemical metal to hold it in place and hey presto problem solved. There's a good thread on it over on focus world
Ian Robinson (10-09-2020)
Old 29-08-2014, 01:04 AM
  #62
hydro st170
hydro st170's Avatar
Originally Posted by box360
easiest way to check if the imrc is working is have someone start the car while you watch the dsi lever, it should pull on start up to the long runner position, then have them rev the car past 5000k it should retract to the short runner position
Is that a part picture? Where did u get it? Ive been looking for something similar with all the engine abit like the Haynes manuals but I know they dont them.Or does some othere place do a manual for a st170.
Old 23-05-2015, 07:24 PM
  #63
mike_krk
mike_krk's Avatar
Hey everyone, I own Ford Focus ST170 (2003) and since a long time I am facing IMRC problem too. The only code that comes up is P1518. I already tied a few attempts to fix it, no luck so far.
1. Firstly I replaced one of the famous transistor inside the IMRC. No problem for about a month, then P1518 came back. At the beginning the check engine light was coming back every few days. 2 days - no problem, then again check engine light for next 3 days. And again and again. What I'm trying to say is that the issue wasn't permanent.
After few more months the check engine light stayed and never went back. After removing the error code it comes back always after about 50km or 3rd engine start.
2. So I sent my IMRC for a regeneration. A lot of parts inside were changed for new ones. Regenerated IMRC was tested on the other vehicle and everything was fine. But after placing it in my car the check engine came again. So basically no difference.
3. Then I asked electrician to check the wires. He checked all IMRC cables, including the signal cable that goes to the driver. Everything is fine.
So...
* IMRC is fine
* Cables are fine too
What else can be wrong? Broken lever? Something else? I've seen an opinion somewhere that "If it's throwing a code it's a bad IMRC, if the lever breaks you don't get a code". That confused me a lot.
Any opinions/solutions? Thanks in advance!
boeb
09-01-2020 05:11 AM
arkeye
Ford Focus ST
20-02-2016 01:22 PM
07-10-2015 12:56 PM
caprixpack
25-09-2015 07:53 PM
Quick Reply: st170 imrc p1518 sticking manifold flaps
