st 170 code error
Old Sep 21, 2011 | 04:48 PM
getgtir's Avatar
getgtir
Default st 170 code error
P0135
P1131
P1518
These codes are comeing up does anyone now wot part do i need and
and how much will it cost.
Old Sep 21, 2011 | 04:58 PM
oldford's Avatar
oldford
P0135 - O2 Sensor Heater Circuit Bank 1 Sensor 1
P1131 - Lack Of HO2S11 Switches - Sensor Indicates Lean
P1518 - Intake Manifold Runner Control Stuck Open (Bank 1)
P1131 is probably caused by P0135. Because the sensor heater doesn't work, there are times where there's no signal from the O2 sensor.
Old Sep 21, 2011 | 05:04 PM
getgtir's Avatar
getgtir
Default faulty codes
so wot do i need to sort this out i havent got a clue wot to do.
Old Sep 21, 2011 | 07:39 PM
kyle_st200's Avatar
kyle_st200
p1518 is easy to do. Open up the IMRC box on the bulkhead and chemical metal the return spring in place so it shuts. Did mine a year ago and run loads better but now mine keeps giving that code even though the spring is still ok so sod knows. Theres a online step by step guide on doing it.
As for the o2 sensor Id put a new sensor in but theyre quite expensive and you need the front one
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
oilman
Sep 23, 2015 11:21 AM
Digispurs
Ford Focus Range
Sep 16, 2015 09:47 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
