What mods for an st170?
Old Oct 10, 2010 | 09:11 PM
morph's Avatar
morph
Default What mods for an st170?
Hi, just bought an nice st170 and want to see what mods are worth getting?
Thanks
Old Oct 10, 2010 | 10:05 PM
ricky_2006's Avatar
ricky_2006
You having a laugh mate.
I've already posted on your previous thread.
Use the search option mate
Old Oct 10, 2010 | 10:43 PM
rstdave's Avatar
rstdave
Save up and buy a focus rs lol....seriously though unless you spend big money on throttle bodies or supercharger/turbo engine wise there's little point bothering as they're well tuned as they are! Exhaust & filter will make it sound nicer....
Old Oct 11, 2010 | 07:09 AM
Depends where you want to end up, a simple ecu swap and mapping session works wonders as the VCT is not at all well controlled with the ford software/ecu.
Old Oct 11, 2010 | 01:23 PM
rstdave's Avatar
rstdave
Will there actually be much in the way of power gains from just an ecu swap though? I'm assuming the characteristics of the engine may change for the better with proper control over the vct, but would you need to be running itb's to see real performance gains??
Old Oct 13, 2010 | 01:24 PM
Sp3no's Avatar
Sp3no
The thing is an ST170 engine started life as a 135bhp blacktop, so it has 35bhp overstandard already. ITB's usually give gains on their own of around 40-50bhp on a 2litre engine with cams so your only really looking at power levels of 185-190ish once you have removed some of the stuff that gave it more power in the first place to fit the ITB's
Listen to Tabetha he knows his stuff, aftermarket managment is not cheap but will get the best out of what you got and if you switch to forced induction or ITB's in the future then your managment will be able to handle this already unlike the standard black oak
Old Oct 13, 2010 | 05:10 PM
martysmartie's Avatar
martysmartie
Replied on your other thread, theres not really alot you can do as I and others said as the engine is already in a highly tuned state. Aftermarket ECU will be mega money for little gain!
Personally from what I have seen the Ford VCT is useless, there are some applications where it makes a huge difference, VTEC for example although given this is a slightly different principle.
Martin
Old Oct 13, 2010 | 06:59 PM
ricky_2006's Avatar
ricky_2006
Martin
Well said son. That's spot on.
Read that ztec_Sam
Old Oct 14, 2010 | 09:35 PM
morph's Avatar
morph
Sorry guys I couldn't find the first post so I opened a new one thinking I hadn't pressed submit.
Old Dec 7, 2010 | 10:21 PM
Magnum PI's Avatar
Magnum PI
I would stick to sourcing a leather interior from the RS Focus and swap it over (if you have a 3 door ST170), change the alloys over to the 17 inch MP3 jobbies and finally change the interior switch illumination to Blue LED's; clock, elec windows, blower controls & aircon/heated screen switches etc (done this in my 1.6 Chic ltd edition & looks mint!)
Old Dec 8, 2010 | 03:15 PM
ajc.78's Avatar
ajc.78
st70 build underway
best way to improve the st170 is to improve the handling stick some eibach springs dampers and arb's on it and you won't be disappointed
al
boeb
Jan 9, 2020 05:11 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
SMILER258
Sep 28, 2015 09:04 AM
