Max/Safe Boost Pressure
Old Nov 18, 2003 | 02:16 PM
Default Max/Safe Boost Pressure
HI!
I'll be picking up my FOcus RS on Friday, do you lot know what type of boost pressure I can run safely?
My planned mods include:
Mongoose Decat Exhaust
GGR Induction Kit
Dump Valve of Some Description (only cos you really cant hear the standard one at all!)
Superchips Blue Fin
Dawes Device Manual Boost Controller
Any help would be greatly appreciated, if any of you are running a Bluefin, what kind of boost does it run? If it turns out to be unsafe to crank it up a little I will simply fit the Dawes to decrease the turbo spool up time.
Cheers!
Old Nov 18, 2003 | 02:57 PM
OldDan's Avatar
OldDan
forget GGR mate.. get down (or up) to SCC...
Old Nov 18, 2003 | 06:28 PM
only fit bailey DV
Old Nov 18, 2003 | 06:39 PM
Why only Bailey?
Oh incidentally mine is Focus 3516, must have been built on or around the same day!
Old Nov 18, 2003 | 07:35 PM
Rob M666SCC's Avatar
Rob M666SCC
Originally Posted by WKD RS
Why only Bailey?
Welcome to the Board mate,
No need for the dawes device when the bluefin is fitted mate, the bluefin adjusts the boost as ness,
In experiance and lots of testing as Dann says only use the bailey dump valve it works a treat.
i would ignore the numbering system, they were completely at random
Any questions dont hesitate to call
Regards
Rob
Old Nov 20, 2003 | 11:10 AM
Thanks Rob, I'll be calling you very soon!
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
SMILER258
Sep 28, 2015 09:04 AM
Russ Payne
Sep 25, 2015 08:29 PM
