Focus RS Mk3 Recall information
Old Nov 4, 2018 | 12:18 PM
R5EjG's Avatar
R5EjG
Default Focus RS Mk3 Recall information
Does anyone have a quick fix on finding out weather the Focus RS mk3
needs the gasket doing?
How do i find out, or is there a link i feed my chassis’ number into that
tells me “it does” or “doesn’t”! Need a recall.
Any information on this would be a great help.
Thank yous !!
Old Nov 4, 2018 | 02:12 PM
_Jimmy_'s Avatar
_Jimmy_
You can look it up on Etis. Make sure Preferences is set to UK then under Vehicle enter the VIN and in the summary it will tell you any outstanding actions (i.e. recall)
https://www.etis.ford.com/home.do
It's cars built up to around the middle of 2017 that need it doing
Think there is also way you can tell by looking under the engine cover at the gasket where it protrudes outside the block, they have different markings and stuff on the edge of the gasket, not sure how exactly what though but kind of shows you where to look in this video at around 5 minutes
Old Nov 4, 2018 | 02:13 PM
focusv8's Avatar
focusv8
There doesn't seem to be anything online.
Ring any Ford dealer, tell the the reg if original and or VIN and they can check.
Old Nov 4, 2018 | 03:26 PM
R5EjG's Avatar
R5EjG
https://www.youtube.com/watch?v=n8mi-9Ypezs
I’ve just checked on etis and it states NO CAMPAIGN MESSAGES FOUND .. Does this mean it won’t need a recall?
Old Nov 4, 2018 | 09:04 PM
Dal_'s Avatar
Dal_
Should be clear then. Mine showed as needing it as it's an early 2016 car - had the work done and the message on ETIS has gone.
Old Nov 6, 2018 | 04:11 PM
R5EjG's Avatar
R5EjG
Great! No recall needed. I can breathe again.
Thanks lads
Chip
Feb 25, 2010 08:36 AM
Gra
Jul 13, 2005 01:20 PM
Aaron1204
Jan 5, 2005 11:43 AM
Little Joe
Jul 8, 2004 03:42 PM
