2.0 in 1.8
Old Oct 26, 2010 | 04:02 PM
Kayble's Avatar
Kayble
Default 2.0 in 1.8
Hey guys, was wondering what all i would need to put a 2.0zetec into my 1.8. Apart from engine and gearbox
CheeRS
Old Oct 26, 2010 | 06:50 PM
woolford's Avatar
woolford
ecu and gearlinkage i think. sure loom is the same
Old Oct 26, 2010 | 07:19 PM
HockeyNomad's Avatar
HockeyNomad
Yep engines and sensors are identical (apart from cylinder volumes) so the loom will be the same, so ECU and engine you should be good to go,
Old Oct 26, 2010 | 07:53 PM
hogdog's Avatar
hogdog
You'll need to keep the clutch and flywheel from the 1.8 and you'll need to use the injectors from the 1.8, the MAF sensor will detect the increased volume of air and make the fueling alterations needed, you don't need a new ECU. It's very straight forward really.
Old Oct 26, 2010 | 08:07 PM
phil_focus's Avatar
phil_focus
if your changing the box aswell you'll need the 2l drive shafts, gear stick and linkage as its lift up reverse.
Old Oct 26, 2010 | 08:46 PM
woolford's Avatar
woolford
1.8 shafts are the same as 2L ain =t they. and whey would he need keep clutch and flywheel when there smaller than 2L????
Old Oct 26, 2010 | 09:01 PM
Escow-Van's Avatar
Escow-Van
2 litre uses a different gearbox from the factory (mtx75 I think), but I imagine the IB5 from the 1.8 will be fine.
Old Oct 26, 2010 | 09:02 PM
hogdog's Avatar
hogdog
So few posts, so much confusion.
If you're changing the box to the 2.0's MTX75 then it's a massive job, you'll need just about everything from the 2.0's engine bay. If you keep the IB5 then it's very straight forward...you just do what I said above.
1.8 and 2.0 driveshafts aren't the same, the splines are different.
Old Oct 26, 2010 | 09:05 PM
Kayble's Avatar
Kayble
OK cool i think il keep the IB5 for now, so i can just get a bare 2.0 (cylinder head, engine block and sump) and swap everything over?
Old Oct 26, 2010 | 09:47 PM
hogdog's Avatar
hogdog
Yep, it should be fairly simple.
mk3ste
Oct 17, 2021 10:09 AM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
The Enigma
Sep 29, 2015 10:31 AM
talon1
Sep 15, 2015 10:27 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
