RS cooling fan?
Old Nov 9, 2008 | 10:42 PM
R5AAL's Avatar
R5AAL
Default RS cooling fan?
My cooling fan on my FRS comes on when i start the car from cold,like even when its frosty outside,i start it then couple of seconds later the fan kicks in.its not the air con as i've checked its off.
Anyone ever heard of anything?
Old Nov 9, 2008 | 11:05 PM
GribbiN's Avatar
GribbiN
The Focus RS has an AUTO air con feature. If you have noticed on the heater controls some of the icons are orange. These indicate Auto aircon, If you have it set to blow on windscreen you have the air conditioning on. Try setting it half way between so it isnt fully on wind screen and the fans will go off. And fuel consumption will improve.
Old Nov 10, 2008 | 10:41 PM
AlexRS2782's Avatar
AlexRS2782
As stated if you point the air flow from the vents onto the windscreen on any fan setting auto air con engages which turns on your engine fans
Old Nov 11, 2008 | 09:50 PM
R5AAL's Avatar
R5AAL
Cheers guys
I'll try it next time i have it out. I had a feeling it would be something daft.
Old Nov 14, 2008 | 04:13 PM
RS16iDale's Avatar
RS16iDale
i have noticed this on mine 2,really happy that its normal
Old Nov 18, 2008 | 10:01 AM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
wtf!
so if you have the heater direction set to the orange windscreen pic then it uses the aircon?!
i've noticed that 3 on the fan control has windscreen next to it and its orange too. Does this use the aircon as well?
I ALWAYS have my heater direction to windscreen in other cars. Just got the frs on sat. I'll stop that if its the case!
Old Nov 18, 2008 | 11:53 AM
AlexRS2782's Avatar
AlexRS2782
Yes & yes - i believe the reason for it though is that its designed to be a "quick clear" setup for the windscreen - very useful at times & yet also annoying at others
Old Nov 18, 2008 | 12:53 PM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
i went on to the rsbb and the FRS section there is very good and i found the info. It also tells you how to remove this
i bought the car on sat and thought the gauge was dropping nice and slow. Between yest and today driving to work in early morning cold conditions with the fan set to windscreen the gauge had dropped quicker. Guess this hasn't helped!
Old Nov 18, 2008 | 01:19 PM
RichieST's Avatar
RichieST
Very easy to get rid of - pretty sure you just have to snip one wire!
Old Nov 20, 2008 | 01:47 PM
GribbiN's Avatar
GribbiN
How to remove this feature
http://bbs.rsownersclub.co.uk/showth...ve+auto+aircon
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Chas
Oct 5, 2015 07:13 PM
rs_jim
Oct 3, 2015 11:37 AM
simonmcf
Sep 22, 2015 08:40 AM
mk1focus
Ford Fiesta
Sep 21, 2015 05:46 PM
