Lights not working
Old Sep 9, 2007 | 02:02 PM
Damo V's Avatar
Damo V
Default Lights not working
On a mates car, not an RS just a normal Foci, his tail lights keep failing...
I havent looked at it yet, but apparently he has changed the switch...
It sounds like a fuse keeps blowing??
Do they suffer from fuse box problems like the escort?
Any common problems to look for?
Old Sep 9, 2007 | 06:42 PM
Focus-Pocus Estate's Avatar
Focus-Pocus Estate
No Matey...No Common Problem with fuse box as i'm aware of...!
if he's recently replace a bulb i would check it's the right one it's been replace with!
otherwise it's a trial and error....i do knowyou can unplug the rear end loom from behind & inside the passenger rear boot pannel to eliminate the short if that helps!!
Good luck...Vince!
jaysoc1
Aug 20, 2015 08:18 PM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
CrOwSoN15
Aug 14, 2015 06:52 PM
