focus rs tuning
Old Aug 15, 2007 | 07:50 PM
bigryrs's Avatar
bigryrs
RSHoleinator
Default focus rs tuning
hi peeps my focus rs turbocharger is cooked and im looking at buying the gt28rs turbo with miltek tubular manifold and downpipe will i need to set the car up afterwards and does any1 recommend keeping it standard and just buying a new turbocharger
Old Aug 15, 2007 | 08:00 PM
AlexRS2782's Avatar
AlexRS2782
All depends on what you want from the car - big power or daily driveability, etc
If you want to run big power id suggest spending more money on the PD manifold mate - have a look on archive posts on the RSOC and you'll see that although the miltek is much cheaper it comes at the expense of poor fitment (i.e grinding down bolts, leaving a turbo bolt off, etc) not good
Bear in mind going the gt28 route you should also budget for a boost controller, maybe a live map, etc, etc
Best bet would be to give Rob @ SCC a call as hes tuned a number of quality FRS (including mine) to high power on the GT28
Old Aug 15, 2007 | 09:55 PM
lankypicker's Avatar
lankypicker
i agree with alex, call scc
Old Aug 16, 2007 | 05:09 PM
bigryrs's Avatar
bigryrs
RSHoleinator
what kinda cash we talking lads
Old Aug 16, 2007 | 07:56 PM
lankypicker
hi mate, call rob at scc, he will go through cost and options with you 01727 867747
i think he cam also sort you out with a refurbed turbo if you want
lankypicker
Old Aug 19, 2007 | 06:01 PM
morph's Avatar
morph
deja vu?
Old Aug 19, 2007 | 06:13 PM
bigryrs's Avatar
bigryrs
RSHoleinator
Default focus rs turbo charger
cheers for the help guys i ordered a turbo from rob at scc he was a big help thanx again
Old Aug 19, 2007 | 06:17 PM
lankypicker
good thing i didnt have to tell you twice!!
Old Oct 8, 2007 | 09:52 AM
joo5ty's Avatar
joo5ty
Isnt it just a matter of buying this at pumaspeed and bolt it on and drive the car?
http://www.pumaspeed.co.uk/showdetails.php?id=505
Old Oct 8, 2007 | 07:05 PM
joo5ty's Avatar
joo5ty
Hi Alex,
I was just looking at your focus RS specs and was surprised to see 400+lfbt of torque !!!!!
Is it really that much? Sounds neckbreaking !!
Can you send me your full specs ? I also like to go for that ! Cheers
Old Oct 8, 2007 | 08:13 PM
AlexRS2782's Avatar
AlexRS2782
Originally Posted by joo5ty
Hi Alex,
Heres the basic engine spec of the car, a few bits i cant list as they're SCC spec specials There will also be more mods & power on the way next year
• SCC spec GT28 hybrid roller-bearing turbo conversion.
• Autronic SM4 ECU management with custom Mike Gurney live-map.
• Autronic closed loop boost control.
• Pro Alloy air to air intercooler conversion with alloy pipes & black silicone hoses.
• Primary Designs black ceramic coated Inconel manifold.
• Primary Designs WRC spec decat back stainless steel exhaust system.
• SCC spec decat.
• SCC/Piper spec camshafts.
• SCC/Piper spec vernier pulleys.
• 4 x 750cc injectors.
• SCC spec Ram-Air Group A air filter.
• Blitz SBC i-color boost controller.
• ‘Ford Motorsport’ 8mm ignition leads.
• Denso ITV27 spark plugs.
• Braided turbo oil lines & feeds.
• SCC spec Group A fuel pump.
• Pro Alloy motorsport spec alloy radiator.
• ‘Cosworth Racing’ WRC spec Focus RS water pump.
• Bailey DV30 recirc dump valve.
• Vibratechnic engine mount.
• Vibratechnic Torque Rod bush
Mods to come:
• SCC supplied Ian Howell spec ported & flowed WRC spec cylinder head.
• SCC supplied Ian Howell spec double valve springs, titanium collets & springs caps.
• SCC supplied Ian Howell custom high flow inlet manifold.
• SCC supplied Ian Howell spec steel pistons & rods.
Old Oct 9, 2007 | 08:06 PM
T4KAF's Avatar
T4KAF
and then wot sort power u hoping 2 b looking at alex??? luv the feature in pf by the way!!!!
Old Oct 9, 2007 | 09:10 PM
AlexRS2782's Avatar
AlexRS2782
Ideally i want to keep the reliability i've had so far, so Rob @ SCC wont be pushing the car to its limits just get it past 400 @ the fly / 350+ @ the wheels it can run safely & reliably without damaging anything & still be driveable to & from track days, work, shows, etc
Old Oct 12, 2007 | 12:34 PM
T4KAF's Avatar
T4KAF
good stuff!!!!!
Old Oct 16, 2007 | 03:41 PM
testastretta999's Avatar
testastretta999
Default Turbo
If you are not requiring massive HP I would suggest GT2860. 0.64 turbine housing good for max 350bhp. 60mm compressor wheel so should spool up ok.
SMILER258
Sep 28, 2015 09:04 AM
Sp3no
Sep 27, 2015 07:23 PM
Marv888
Sep 26, 2015 03:44 PM
Tank Mike
Sep 26, 2015 08:07 AM
RSBryden
Sep 6, 2015 08:39 PM
