Focus RS water temperature question
Old May 31, 2007 | 08:21 AM
sailorbob's Avatar
sailorbob
Default Focus RS water temperature question
What's considered to be the 'normal' water temperature for a standard Focus RS? I ask because I had the chance to go around Cadwell yesterday with a mate and thought that the temperature was a little high as it was hovering around 100 deg C but on the way back the temperature was still typically between 95 to 98 deg C during normal driving.
Thanks.
Old May 31, 2007 | 09:14 AM
COCHYN's Avatar
COCHYN
They normally sit around 96-99C, then occasionally fire up to 101C (to which the fan automatically comes on) when given a good pasting or sitting in traffic too long....
Old May 31, 2007 | 09:15 AM
pd689's Avatar
pd689
TBH it depends, my SPA gauge which reads off the top rad hose sits at 88-90 deegrees, but my scangauge which reads the ecu data off the block sits at 98-100.
Paul
Old May 31, 2007 | 09:42 AM
sailorbob's Avatar
sailorbob
Hmm, looks to be normal then and obviously set up for emissions rather than performance.
I wonder if there's any merit in fitting a lower temperature thermostat and lowering the fan on/off settings
Old Jun 1, 2007 | 06:42 PM
chriz111's Avatar
chriz111
If you had a stratagem unit you can lower both low speed and high speed fans
But it seems they do run hot so nothing to worry about.Copes o.k.
Old Jun 1, 2007 | 10:21 PM
sailorbob's Avatar
sailorbob
I think I'll be able to find the fan on/off settings without the expense of a Stratagem Only 60 thousand plus lines of code to rummage through at a guess.
Old Jun 2, 2007 | 08:44 AM
zvhrst's Avatar
zvhrst
mine runs about 98/100 when i was on track i plugged data logger in obd port and it recorded a peak of 105,
since melted the engine
Old Jun 2, 2007 | 03:17 PM
sailorbob's Avatar
sailorbob
Ouch, was it a standard engine and do you know why it failed?
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
RSBryden
Sep 6, 2015 08:39 PM
gavt123
Sep 5, 2015 10:03 AM
Sep 3, 2015 10:49 AM
