FRS lumpy tick over...
Old Mar 19, 2007 | 03:12 PM
jamesy131's Avatar
jamesy131
Default FRS lumpy tick over...
hi, since I have installed a blue fin I have been having some problems with lumpy tick over and occasionally while slowing down to a stop the engine has stalled when ive been changing down. The car is otherwise standard apart from a K&N induction kit and a collins dump valve. Any ideas would be appreciated, thanks.
James
Old Mar 19, 2007 | 03:39 PM
kmrobertson3's Avatar
kmrobertson3
Is your dump valve vent to atmosphere? if so this will cause your car to cut out at junctions and stuff. My advice would be to go back to recirc dump valve or the combination dv from Forge.
Old Mar 19, 2007 | 04:30 PM
jamesy131's Avatar
jamesy131
Default dump valve...
yes my dv does vent to atmosphere. Ill check out the combination dv you suggested from forge, thanks for the tip.
James
Old Mar 19, 2007 | 06:26 PM
AlexRS2782's Avatar
AlexRS2782
Sounds like the atmospheric dv as Keith has said - they can cause the car to stall in the way you've described - had a bailey dv26 had the same probs and returned to recirc in the shape of a bailey dv30
Old Mar 19, 2007 | 08:00 PM
jamesy131's Avatar
jamesy131
Default DV
wish i had asked the question about which dv to fit in the first place! Thanks again for the tip....
James
Old Mar 20, 2007 | 08:54 AM
zvhrst's Avatar
zvhrst
i fitted a bailey DV26 and had this problem,
since changed to a no-mad racing double piston type, stil atmospheric, and i dont get this problem now,
altho when i dont take it to full boost it doesnt dump, i get fluttering at anything up to .6bar of boost
it only dumps when i go over .6 bar of boost
NZWINRZ
Ford Focus RS
Jan 28, 2020 09:24 PM
Fiddy
21
Sep 29, 2015 06:10 PM
dojj
Sep 8, 2015 08:31 AM
stevierob
Sep 7, 2015 07:09 PM
IanC
Sep 5, 2015 09:38 PM
