erratic speedo
Old 03-07-2006, 04:32 PM
steven botes
steven botes's Avatar
Default erratic speedo
my 2001 2L focus hatch sometimes has a problem with the speedo , it drops down to zero while cruising , and the electronic lcd display goes blank.it comes back after a few minutes
Apparently this has to do with software bugs?
any ideas?
Old 04-07-2006, 05:50 AM
Willow
Willow's Avatar
sounds connected to your interior boot lid button issue - sounds like a connector on the back of the console has come loose - would explain both problems.
have you been to ford about it?
Old 04-07-2006, 02:24 PM
Twisterboy
Twisterboy's Avatar
Hi mate, your speedo dropping to zero is the VSS sensor as mine does this, I would take this to ford I think it costs about £30 for the part and whatever ford charge for labour, this is due to wear and tear of the sensor, which I think is in the gearbox.
Hope this helps you.
Davy
Old 04-07-2006, 03:57 PM
Big AL
Big AL's Avatar
Would appear to be the VSS, £25 from Frauds or about £80 fitted, can be a PIA to fit as the pin breaks when removing, have been informed to pour a kettle of hot water over the box to make extraction easier.
try a self diagnostic check and see if you get any dtc codes.
Follow the instructions listed on the following thread
http://forum.ffoc.co.uk/forum/viewto...a2d4ea103559f0 613b893cda816e1e0d
cossie brad
29-09-2015 02:38 PM
IainRS1700T
25-09-2015 06:44 AM
sto6enc
Ford Mondeo Including ST
21-09-2015 11:31 AM
Bransby
14-09-2015 08:54 PM
Escortdriver1
31-07-2015 02:36 PM
Quick Reply: erratic speedo
