Ford Focus Range This Section Contains All The Ford Focus Model Specific Forums.
Constant Fans
Old Oct 8, 2013 | 02:01 PM
norfolklondoner's Avatar
norfolklondoner
Default Constant Fans
Hi all,
New to focus ownership and I have a question about the fans.
I've owned my ST170 for a few weeks now and I've noticed that the fans are permanently on when the engine is running regardless of temperature, both fans at full speed. The temperatures seem fine and the oil and water temp build and modulate as expected.
I did find what looks like a temperature sensor cable tied to the side of the battery box, I'm unsure where this is supposed to go, please see picture:
Any advice would be greatly appreciated, thanks
Old Oct 8, 2013 | 03:14 PM
JamboRS's Avatar
JamboRS
focus rs 1672
Originally Posted by norfolklondoner
Hi all,
do you have the knob on the dash set to window(orange) the fan will come on with that set to that.
Old Oct 8, 2013 | 04:04 PM
norfolklondoner
thanks for the reply.
Yes the heater is set the windscreen yes and to be honest I dont think I've ever changed it.
I'm talking about the radiator fans by the way, just to clear up some confusion.
Old Oct 8, 2013 | 05:02 PM
liam-rst's Avatar
liam-rst
shit happens
Its the air con that kicks in on my focus when I put the fans to windscreen and that still only comes on when the heater fan is switched on
Old Oct 8, 2013 | 05:31 PM
mcst's Avatar
mcst
Its the Aircon as above, when you have the setting on just windscreen the air con is always on to demist. Aircon dehumidifies in winter, don't use it above fan speed 3 though as it can crack the screen on really cold mornings.
Knock it back to screen/foot and the a/c will be off unless you switch it on with the separate button
Old Oct 9, 2013 | 07:47 AM
norfolklondoner
Thanks.
Well thats solved the constant fans question.
But does anybody know what the sensor is for? It looks like a temperature sensor but I'm not sure where from?
Old Oct 10, 2013 | 10:08 AM
mcst's Avatar
mcst
Thanks.
IIRC mines like that too, mrs has the car at the minute so can't check but i'm sure its supposed to be there......don't hold me to it though!
Old Oct 10, 2013 | 10:13 AM
norfolklondoner
Could it be a sensor used on another variant of Focus that shares the same wiring harness? So it is redundant on the ST170?
Old Oct 10, 2013 | 06:59 PM
mcst's Avatar
mcst
I'd think thats it.
Old Oct 11, 2013 | 12:27 PM
martysmartie's Avatar
martysmartie
Thanks.
That is a Ford special bodge lol, it's an additional sensor which activates the fans when the under bonnet temps get a little hot.
Martin
Old Oct 17, 2013 | 09:08 PM
Our focus fans are on most of the time too.When we first start it up the fans will kick in.
Old Oct 18, 2013 | 03:35 PM
mcst's Avatar
mcst
If its on the windscreen setting they will be, the a/c is on. If not you've another issue
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Chas
Oct 5, 2015 07:13 PM
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
mk1focus
Ford Fiesta
Sep 21, 2015 05:46 PM
