Ford Focus Range This Section Contains All The Ford Focus Model Specific Forums.
Read this before you replace your maf!
Old May 19, 2013 | 05:51 PM
xenton's Avatar
xenton
Enthusiastic Novice
Default Read this before you replace your maf!
A lot of people replace their MAF because it maybe causing a problem. You can check if your MAF is faulty by simply running the car with the MAF disconnected (note - this will store a fault code). If the problem goes away when doing this, then your MAF is faulty and should be replaced. If not, then it's most likely something else.
Old May 19, 2013 | 05:54 PM
RichieST's Avatar
RichieST
Not true. Disconnecting the MAF will just put the car into limp mode, which will then only use sensors that are necessary for the engine to run like the crank sensor, and disregard the info from a few other sensors that are just there for fine tuning and emission control etc.
Old May 19, 2013 | 05:59 PM
xenton's Avatar
xenton
Enthusiastic Novice
It's been my experience that a focus with a serious MAF fault will run better in 'limp home mode' than with the MAF attatched, and this could save a needless MAF replacement.
Mark_
40
Oct 2, 2015 04:40 PM
muzzman1
Sep 30, 2015 08:59 PM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
KennyWelsh
Ford Focus (All Models)
Sep 13, 2015 08:28 PM
