Ford Focus Range This Section Contains All The Ford Focus Model Specific Forums.
Bearings for a ST170
Old Nov 16, 2012 | 11:54 AM
R-A-J's Avatar
R-A-J
Default Bearings for a ST170
As above really, freshening up my engine and wondering which brand to go for as there a various makes with ranging prices, is it a case of you get what you pay for or are some companies just chargin extra for a name?
Any help would be great
Many thanks
Raj
Old Nov 16, 2012 | 11:58 AM
R-A-J's Avatar
R-A-J
just to add im after the big end bearings and crank bearings
Old Nov 16, 2012 | 01:00 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
Acl are pretty good and reasonably priced if you get them from the right place
Old Nov 19, 2012 | 11:11 AM
R-A-J's Avatar
R-A-J
Many thanks for that,
do you have a places you would recommend?
Old Nov 19, 2012 | 11:30 AM
R-A-J's Avatar
R-A-J
just had a look on the bay and noticed heavy duty bearings for £88 and £120, are these worth it for a na car? Really not sure what the difference is between these and normal ones
Old Nov 19, 2012 | 04:08 PM
dug112y's Avatar
dug112y
passionford pro
they will be better quality i imagine. glyco bearings will do the job just measure them correctly with plastigauge.
Old Nov 19, 2012 | 09:35 PM
R-A-J's Avatar
R-A-J
the glyco bearings seem very cheap, has anyone used these bvefore or got any feedback regarding them
cheers
Old Nov 19, 2012 | 10:11 PM
dug112y's Avatar
dug112y
passionford pro
You ask for advice then question it when it's given!!
I've used them loads of times no problems... I've seen Ian Howell using them . If you want to buy the expensive ones charge on.... But if they are not measured right your engine will break!!
Old Nov 19, 2012 | 10:17 PM
R-A-J's Avatar
R-A-J
Thanks dug, was'nt questioning you, just wanted confirmation that either you or someone else had used them, cant be too careful with people stating facts they have obtained by hear say or my friend told me etc, but as you have clearly stated you have used them yourself then thats good enough for me.
Im trying to get an appropriate haynes or equivalent manual for the engine so I can start putting it back together.
Thanks for the advice
Old Nov 19, 2012 | 10:31 PM
Turbo Zetec
Engine Machinist
get them from any reputable machine shop, but don't be surprised when they tell you that ACL don't list heavy duty bearings for the zetec, because the ones that everyone sells as 'ACL race bearings' for the zetec are just standard ACL zetec bearings.
glyco should be fine too really!
*edited to say i have used both ACL and glyco in a zetec and they ARE fine! no internet hearsay here, i work in a machine shop, so see this kind of thing every day
Old Nov 27, 2012 | 12:24 PM
R-A-J's Avatar
R-A-J
Really appreciate that mate, ordered some High comp pistons and rods from the states so should be getting the rest of the gubbins ordered soon.
Many thanks for you help
Raj
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
tankybaby66
Feb 6, 2016 02:24 PM
89barto89
Oct 4, 2015 06:59 PM
fordrallycar
Sep 30, 2015 07:57 PM
20/20 vision
Sep 28, 2015 03:03 PM
