Ford Focus Diesel This forum is for discussion of all things pertaining to the Ford Focus Diesel Range.
2.0 tdci vss speed sensor question
Old 01-10-2014, 03:06 PM
andyt1992
andyt1992's Avatar
Default 2.0 tdci vss speed sensor question
Hi,
Does anyone know where the speed sensor is located on the 2.0 tdci focus had a good look around but can't find it. also cant find a reference to it in the Haynes manual.
Any help or pictures etc would be very helpful!
Thanks,
Andy
Old 02-10-2014, 08:51 AM
andyt1992
andyt1992's Avatar
anyone please? I really cant see it on the transmission housing anywhere and my car keeps cutting out after a mile or so..
Old 02-10-2014, 11:32 AM
Piston Broke
Piston Broke's Avatar
its in the gearbox mate top near the bulk head
Old 02-10-2014, 12:00 PM
andyt1992
andyt1992's Avatar
Cheers fella, I'll report back tonight would you know if it's accessible without removing other parts?
Old 02-10-2014, 12:31 PM
Piston Broke
from the underside looking up yes you can get to it mate, there is a pin holding it in and can be a right twat to get out
Old 02-10-2014, 02:18 PM
GVK.
GVK.'s Avatar
If its a mk2 Focus (or even some very late mk1)... they don't have a VSS the vehicle speed info comes from ABS via high speed can to PCM and instruments.
Old 03-10-2014, 08:51 AM
andyt1992
andyt1992's Avatar
This is correct after another hour or so swearing and screaming last night I still didn't manage to find the vss... it doesn't have one despite the garage saying that's what I need and the part being on the system under the reg!
So the next question is with diagnostics code c1155 N/S ABS wheel speed sensor.. should I just jump to buying the sensor and fitting it or is there any other investigations I can do to check the faults origin?
Music & Car Audio Chat
03-09-2017 01:24 PM
15
07-10-2015 03:43 PM
Kam B
24-09-2015 10:40 AM
rsturbo27
05-09-2015 05:08 PM
hopper350
04-09-2015 12:53 AM
Quick Reply: 2.0 tdci vss speed sensor question
