Ford Focus Diesel This forum is for discussion of all things pertaining to the Ford Focus Diesel Range.
Which tdci is best for me?
Old 23-02-2012, 04:22 PM
kaitechno
kaitechno's Avatar
Default Which tdci is best for me?
Howdy all.
I'm currently thinking of buying a focus diesel and am wondering which engine is best for me.
I am a driving instructor so reliability and fuel economy are most important for me, although I currently have a fabia vrs and am no stranger to a spirited drive so I'm wondering whether the 1.6 might be a bit underpowered for me. I've also sussed that the 1.8 is an older engine and the 2.0 has certain issues with it.
Can anyone enlighten me further as to which is best?
Old 23-02-2012, 04:24 PM
Danster76
Danster76's Avatar
If I was you, I would have the 1.8tdci.
Old 23-02-2012, 08:11 PM
kaitechno
kaitechno's Avatar
Does anyone know if reliability differs between the different engines? If so, what sort of issues tend to crop up?
Old 25-02-2012, 11:03 AM
uruk hai
uruk hai's Avatar
As above, I would go for and I do have a 1.8 TDCI (I think they were fitted up to 2009 !) ! As you rightly say they are an older design and while they may not produce the power or fuel economy figures of the others they are a good and well proven engine and they don't have the troublesome DPF's that the others have ! Having said that like almost all diesels they aren’t trouble free and if you’re using it to teach then you will expect to be replacing the clutch and probably the dual mass flywheel as well, this is a straight forward job but can be costly and as you’ll be aware instructor cars will go through these parts quicker than normal. Other things that can go are obviously the turbo and possibly injectors and fuel pumps, although as with most modern cars they will if correctly maintained give good and mainly trouble free service.
mark94
Ford Mondeo Including ST
10-10-2023 06:52 PM
Tank Mike
Ford Focus Diesel
23-02-2022 06:09 PM
The Enigma
29-09-2015 10:31 AM
Sp3no
27-09-2015 07:23 PM
talon1
15-09-2015 10:27 AM
Quick Reply: Which tdci is best for me?
