Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
Engine swap from focus 1.6 tdci into peugeot 3008 1.6 hdi dv6ted engine
Old 01-02-2016, 11:45 AM
Bigdaggy123
Bigdaggy123's Avatar
Default Engine swap from focus 1.6 tdci into peugeot 3008 1.6 hdi dv6ted engine
Hi all, I have a PEUGEOT 3008 1.6 HDI with a seized engine and I've purchased a ford focus 1.6 tdci engine from a low mileage 2008 model, now I've been told that the 1.6 tdci engine dv6ted lump is exactly the same engine that's used in the ford PEUGEOT CITROEN Volvo & mazda, but I'm wanting to know if this engine I have from the focus 1.6 tdci will go straight into my PEUGEOT without having to swap the fuel pump, injectors or anything else over, ill be swapping the accilaries and stuff over from the ORIGNAL pug engine but do I need to put the pug fuel pump and injectors onto the focus engine as I'm not sure if there coded to the pugs ecu, can anyone help me out
Old 01-02-2016, 01:03 PM
Badman38
Badman38's Avatar
don't know about the hdi dv6 engine but defiantly the 1.6tdci don't need coding i9 have changed mine many a time, is yours the 90hp or the 110hp engine? should just swap over everything the same, the dv6 engine changed to an 8v but I think that's on the 2010/2011 models.
Old 01-02-2016, 03:41 PM
Bigdaggy123
Thanks for getting back to me, I don't know if its the 90hp or 110hp the PEUGEOT engine code is supposedly 9hy but on the block all I can find is 9h01, I spoke to someone earlier today who said the pug engine isn't coded to the fuel pump or injectors and that all the copings through the ecu, I just don't want to put this focus lump in the car to find out I've gotta change this that and the other and it end up been a headache, I have the engine out of the PEUGEOT and the new focus lump sat at the side of it ready to swap all the bits over and get it thrown back in, I just needed someone else's advice to get me on the right track, so u think the engine should just go straight in n crack up,
fordnutsboltsclipsscrews
15
22-06-2022 06:05 PM
24-10-2016 08:58 PM
Ford Focus RS Parts for Sale.
21-01-2016 12:38 PM
18-01-2016 05:11 PM
Ford Range
14-01-2016 01:30 PM
Quick Reply: Engine swap from focus 1.6 tdci into peugeot 3008 1.6 hdi dv6ted engine
