Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
focus headlight removal
Old Jan 24, 2016 | 05:20 PM
busdriver1's Avatar
busdriver1
Default focus headlight removal
hi changed healight mainbeem bulb a couple of wks ago easy couple bolts to undo slipped out no bother
today had to do nearside sidelight out same thing took front plastic cover of undo the two bolts tried to slide it out it moved but would not come completly out so put it back together
anybody else had same prob on nearside removel ford focus 2005
thanks
Old Jan 24, 2016 | 05:53 PM
RichieST's Avatar
RichieST
There is a bolt underneath the light, you need to reach your hand up behind the bumper to remove it. Sounds like whoever changed the bulb last on the other side didn't put it back in!
Old Jan 24, 2016 | 08:38 PM
busdriver1's Avatar
busdriver1
thank you so its a lay on ground then up under the skirt
thanks a lot
Old Jan 24, 2016 | 09:53 PM
botters's Avatar
botters
competant bodger
what year focus? the newer ones have two bolts at the top and a plastic tab down the back of the headlight that you press down to remove the light
Old Jan 24, 2016 | 11:01 PM
busdriver1's Avatar
busdriver1
2005 1 .6 zetec 5 door
Old Jan 25, 2016 | 11:42 AM
H3lsing's Avatar
H3lsing
ffoc.co.uk
The mk1 has 4 bolts, 3 are visible and 1 accessible under the wheel arch by first removing torx screw bit that screws onto lower end corner of bumper. It's a tight fit but can be done if your patient. They are all 10mm bolts.
Jan 13, 2016 04:48 PM
Mrig1992
13
Dec 29, 2015 10:27 PM
JanDK
Dec 29, 2015 03:33 PM
GHIA
Ford Focus Range
Dec 28, 2015 10:52 AM
oli49521
Dec 26, 2015 07:53 PM
