Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
headlight bulb replacement
Old Jun 17, 2014 | 05:32 AM
youngalistai's Avatar
youngalistai
Default headlight bulb replacement
that old nutshell again ! had my first induction today on trying to replace the front headlight bulb passenger side on a mk1 as ive read since this is a bitch of a job anyway carried it out the first problem is getting the back cover off! i completed the work blind then it came to the very last detail putting the cover back on! im stumped and dont want to take off all the battery as will lose my code apart from everything else.....can i saw off lugs of the cover as this seems the sticking point in trying to re-position the cover back in place do i really need them? will cover still be secure if i whip them off and just use the clip bar ? or will it still not fit leaving me to buy another cover or just fall off somewhere being not secured any longer at the top ?
Old Jun 17, 2014 | 06:54 AM
RichieST's Avatar
RichieST
Just take the headlight out. One or two bolts at the top and one underneath. 2 minutes and it's out. Don't go cutting g anything as if it doesn't seal properly it will fill up with damp.
Old Jun 17, 2014 | 06:57 AM
youngalistai
ok i will try that thanks
Old Jun 17, 2014 | 05:34 PM
mcst's Avatar
mcst
Look it up on YouTube, you need to undo the arch liner to access a hidden bolt and remove the lamp. 10 minute job as opposed to the hour pissing about trying to get those fucking covers back on.
Old Jun 17, 2014 | 06:29 PM
RichieST's Avatar
RichieST
I've never removed an arch liner. Just reach you hand up under the front bumper and you'll be able to feel the bolt.
Old Jun 17, 2014 | 07:32 PM
mcst's Avatar
mcst
You just undo the bolts on the leading edge for access, you don't need to remove the whole liner.
Mc5506
Oct 5, 2015 09:57 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Steve Escos
Oct 1, 2015 06:57 AM
mondeomark
Sep 28, 2015 06:28 AM
