Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
Focus T190 sensor.... What is it???
Old Jun 5, 2011 | 07:34 PM
Camel Fiddler's Avatar
Camel Fiddler
Resident Camel Stalker
Default Focus T190 sensor.... What is it???
What's this sensor for exactly? It's just above gearbox on the n/s of the engine on the water hose lines. Pump maybe?
Old Jun 5, 2011 | 08:29 PM
focus 4x4's Avatar
focus 4x4
Is it in the block or the head?
Old Jun 5, 2011 | 08:36 PM
Camel Fiddler
Block. The pipe in foreground is the crankcase breather on front of block with gearbox in the background and water hoses also visible.
Old Jun 5, 2011 | 09:10 PM
focus 4x4's Avatar
focus 4x4
Well this is an oil switch for this car.......
Old Jun 5, 2011 | 10:14 PM
Camel Fiddler
That where the oil switch is?
Old Jun 26, 2011 | 01:18 AM
pdfbt40's Avatar
pdfbt40
No it isn't.
What you are looking at is the thermostat housing. Normally that location wouldn't have any sensors on a Focus.
On a Mondeo that location has a water temperature sensor only connected to the dash gauge. Another sensor in the top of the housing connects to the PCM for engine management. The Focus management uses one sensor (dry) in the cylinder head above #1 for both these functions.
Often when people add separate management they add sensors into thermostat housing as its easier than sharing one. So its likely to done for that reason by Mountune or Gordon Spooner, or a subsiquent owner.
Martin
wowk
Mar 30, 2021 07:49 PM
tankybaby66
Feb 6, 2016 02:24 PM
Sp3no
Sep 27, 2015 07:23 PM
Tank Mike
Sep 26, 2015 08:07 AM
