Where is the fuel and pollen filter on a Zetec S
fuel filter is located under car on passangetr side just infront of the pertol tank and all you need is a torx srewdriver and you fingers but make sure you get the flow the right way
and the pollen filter is also on the passnger side off the car under the bonnet 2 simply clips and then pull the filter out and push the new one in easy
JK12
33
26-04-2021 01:09 PM
