REPLACING BONNET CABLE??
Old Jan 29, 2006 | 05:13 PM
COSSIE 1's Avatar
COSSIE 1
Default REPLACING BONNET CABLE??
Mines broken and frayed at the pulleydowny thingunder the steering column , is it difficult to replace with a new one? and how much r they to buy, cheers peeps....p.s i can get into the engine bay still buy pulling the cable with a pair of pliers
Old Jan 29, 2006 | 05:18 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Easy to fix
Old Jan 29, 2006 | 05:58 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
Yeah, pretty easy to replace if your loom is tidy behind dash.
Take the steering cowling off at the bottom and feed it through from the car out to the bonnet. Yes, if you pull on the cable it will release the bonnet.
Old Jan 29, 2006 | 06:01 PM
COSSIE 1's Avatar
COSSIE 1
any idea how much
Old Jan 29, 2006 | 06:02 PM
Tony Turbo's Avatar
Tony Turbo
Ł14 ish
Old Jan 29, 2006 | 06:14 PM
COSSIE 1's Avatar
COSSIE 1
cheers mate will sort out asap
Old Jan 29, 2006 | 06:18 PM
Tony Turbo's Avatar
Tony Turbo
Old Jan 30, 2006 | 06:10 PM
stevos1's Avatar
stevos1
i went to my local breakers yard 2day and bought a mk4 escort bonnet cable and found sum dark rear lights cost Ł20 the lot
easy to put on pull the old one out i suggest taping sum string to it then using the string to pull the new 1 through the connect it up and job done
Old Feb 2, 2006 | 03:07 PM
andre_k's Avatar
andre_k
yup, tape the new one to the old, and pull through... took me 5 mins
Mark_
40
Oct 2, 2015 04:40 PM
muzzman1
Sep 30, 2015 08:59 PM
Flatlinedan
Sep 18, 2015 12:41 PM
Adam Graham
Sep 6, 2015 06:04 AM
