efi or mfi turbo?
OFABs only better cos you can run a Cossie map sensor, OFAC can still run upto 17psi which will easily see over 200bhp anyways
MFi isn't necessarily bad for tuning, people have seen good power on it...
if you get an EFi loom from an XR3i you can change the whole lot rather than splicing it into the Escort MFi loom, will look a lot neater plus the ECU will be in the car rather than in the engine bay
