rust ? waxoil?
rust ? waxoil?
right dont mean to sound dum or anything want advice on how to do it properly ? ive jet washed the bottom off my car to see how things looked got 2 big ish holes size of a 50pence picece and they will get welded and did the same to the arches have a lagre amont of rust everywhere whats the best way to stop it getting worse ? clean then paste evenly with waxoil or rust stuff?????
cheers jamie
cheers jamie
It Wasnt Me!
rub all the surface rust off, sand paper/wet n dry/grinder (bit harsh), treat it with some rust treating stuff cover in stone chip, and paint i'd reckon. sure someone will correct me if im wrong
JayRS2000
And on top of that paint it VERY well, then lots of underseal on the underneath, cut it out properly and prep the new plates and they will last years. The only way to totally remove rust is to remove the whole panel, not very easy with the floor though
Originally Posted by antony215
Only way to do it is to cut all the rust out and have new plate's welded in
Originally Posted by 32a tuning
don't do anything till you have had it welded. Just makes it harder to weld
badly worded
Escort Rs Turbo
Originally Posted by rst in progress
if your welding the floor take the carpet up and treat inside to other wise you'll create a rust trap due to it being untreated
id say he will create a BIG!!!! fire
07-10-2015 12:56 PM
