Actuator setting
I just fitted my electronic boost controller and has settings for hi and low boost, I have a -31 actuator, what boost shall I set this to before setting the boost electronically?
cheers
cheers
mine runs 8 and 18 but then the motor is far from standard be careful you dont want to put a rod threw the block by running silly psi if you have a standard motor
JK12
33
Apr 26, 2021 12:09 PM
