Electric Window problems
Old Nov 24, 2003 | 10:32 PM
Norton's Avatar
Norton
Default Electric Window problems
when i first got my s2, in the summer, the passenger window was really slow to go back up, but the drivers side was fine. Now its got to winter and its cold, they have both gone slow, really really slow. I dont open the windows any more coz it takes several minutes for them to go back up and sometimes they look like they wont go back up at all. Anyone had any similar probs? or know what it might be?
cheers.
Old Nov 25, 2003 | 06:58 AM
adamS2RST's Avatar
adamS2RST
Yep, classic problem mate. Mine are sometimes like this, I find that putting a small amount of pressure on the glass and helping them back up works ok. If you find them going really slow, this means they are taking all the charge outta your battery, leccy windows take a lot of power to go up and down, but the main cause would probably be the electric window motors are knackered, mine does it too, but I'm not too fussed about it at the mo, I think most RST's do it tbh.
Old Nov 25, 2003 | 10:10 AM
Norton's Avatar
Norton
i dont really want windows open in this weather anyway, its too cold.
But when im reaching out for the ticket at the car park and im sat for ages waiting for windows, it gets a bit annoying
Old Nov 25, 2003 | 11:06 AM
adamS2RST's Avatar
adamS2RST
LOL - Yea I know what you mean. Well the thing I would do is to look at the motors and change them if possible
Old Dec 6, 2003 | 06:53 AM
RickRS1976's Avatar
RickRS1976
put some vaseline on the runners inside the door it helps!
Old Dec 7, 2003 | 07:47 PM
strange both windows are goin slow as its usually the pass side as it gets less use ............... could make sure all the plugs are tight , could be a bad earth or like the lads have said the windows need lubricating........
Old Dec 7, 2003 | 09:54 PM
adamS2RST's Avatar
adamS2RST
I think i need to do this to mine, they are becomming ever slower
Old Dec 9, 2003 | 08:49 PM
F923ANV's Avatar
F923ANV
try spraying silicon onthewindow rubbers
Old Dec 9, 2003 | 09:14 PM
adamS2RST's Avatar
adamS2RST
I think mine is the runners in the door, still i got two new doors to fit and strip electrics off and refit so will do it then
Old Dec 9, 2003 | 09:49 PM
on my s1 if i open the passenger side window from drivers controls it takes forever to open & the same when i close it but if i open it from the passenger control its fine. Drivers side window is fine thou. It does my head in!!!!!
Old Dec 9, 2003 | 09:50 PM
Old Dec 9, 2003 | 09:51 PM
F923ANV's Avatar
F923ANV
sounds like bad contactsinthe switch to me
Old Dec 9, 2003 | 10:12 PM
Cheers m7, i'll have to look into it.
Old Dec 13, 2003 | 06:23 PM
Seein as i have to work with replacing door glasses most of the day, firstly lubricating the front and rear channels helps a helluva lot, and also popping the door card off and re greasing the runners and the runners poppers.
Also come across another problem every now and then with the secondary runner guide that holds the glass level (two 10mm bolts holding smaller runner to rear of door)
Re-grease this runner, and crack the nuts so the runner goes slack, move windo up and down once or twice, and adjust the runner accordingly to the best movement. common problem with the secondary runner moving for no reasonafter
Old Dec 14, 2003 | 07:10 PM
Norton's Avatar
Norton
my alternetor was loose, so my battery wasnt charging and the windows were really slow and battery went flat a few times. Ive had it tightened up now so they are both slightly faster, altho the passanger side is still slower.
Old Dec 14, 2003 | 07:17 PM
adamS2RST's Avatar
adamS2RST
Cheers for the advice till
Old Jun 26, 2019 | 08:27 PM
Spicy's Avatar
Spicy
Smile electric beam ford escort rs turbo
Hello, guys do you know anyone tat sells the whole electric beam or can supply me a lot of picture of it and lengths to duplicate it thanks a lot
Old Jun 26, 2019 | 08:37 PM
Spicy's Avatar
Spicy
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
Kam B
Sep 24, 2015 10:40 AM
focus2351
Sep 9, 2015 09:33 PM
