intercooler
Old Sep 26, 2005 | 07:05 PM
turbocabs's Avatar
turbocabs
Default intercooler
i have a pace double size fitted whats the max hp i could get out of this
thanks peeps
Old Sep 26, 2005 | 07:30 PM
swerv's Avatar
swerv
18 psi really depending on fuelling , probably push around 190-200hp before the temps bring it down
Old Sep 26, 2005 | 07:54 PM
James Raby's Avatar
James Raby
Agreed, was going to say 18psi myself
Old Sep 26, 2005 | 09:18 PM
Rick's Avatar
Rick
it depends on ur engine. One with a big turbo and a good head would probably goto 240hp - u cant measure power in terms of intercooler.
Old Sep 26, 2005 | 09:23 PM
James Raby's Avatar
James Raby
but boost pressure
Old Sep 26, 2005 | 09:52 PM
turbocabs's Avatar
turbocabs
thanks 4 the feed back
the spec is
late 2l zetec bottom end with cosworth rods and pistons arp bolts lightend fly wheel. fiesta turbo head piper 285t2 cam double valve springs fiesta turbo inlet manifold cozzie throttle houseing green injectors 3 bar map sensor group a coil l6ecu with piggy back mongose exhaust hybrid turbo lets see how long gear box last
Old Sep 26, 2005 | 10:12 PM
James Raby's Avatar
James Raby
ditch the double size FFS lol
GRS cooler will do you well
Old Sep 26, 2005 | 10:14 PM
turbocabs's Avatar
turbocabs
im worried about over heating problems
Old Sep 27, 2005 | 04:06 AM
James Raby's Avatar
James Raby
get 2x10in kenlowe fans to go with it and an 82 degree thermostat then you WON'T have any problems
Old Sep 27, 2005 | 06:52 AM
Rallyesport's Avatar
Rallyesport
What is the number on that 82 degree thermostat?
Old Sep 27, 2005 | 12:14 PM
James Raby's Avatar
James Raby
meaning?
Speak to Christian @ APT he can sell ya one cheap
Old Sep 27, 2005 | 04:45 PM
zippyobrien's Avatar
zippyobrien
hi
just after the phone number or email/website for ATP, could do with one of those thermostats.
also im running a solid 1.4bar (21psi) and i have a pace double capacity and to be honest, its pants!!!!!!!!!!!!!!!!!!!!
Old Sep 27, 2005 | 04:49 PM
zippyobrien
.on that subject, has any one else got any good ideas on how to bring water temps down , ive got a swirl pot, bonnet lifters and im going to try this thermostat. i was going to disconect the water cooling from the turbo (its a stage 3 t3) but will it cause any really rapid wear or instant falire. 9im not bothered if it reduces its life a little bit)
cheers
addiction's Avatar
addiction
i used to run the same Pace intercooler on my 1.8cvh and the ACT's were through the roof!!!! best thing i ever did was fit a GRS cooler,ACT NEVER goes above 34 now
Old Sep 27, 2005 | 05:10 PM
Rick's Avatar
Rick
Before u ask about water temps - u need to say where u are suffereing? Crusing on mway? Sitting in traffic?
Old Sep 27, 2005 | 07:31 PM
zippyobrien
sits at about half way in traffic (about the 'o') however when crusin (loadin it up every now and again it can fluctuate alot. if i put my foot down for a bit the needle starts heading for the red and can take about a mile to chill out. also when bommin round town the neddle varys from the top of the 'n' to near the bottom.
i have gota little bit of a missfire at full boost but even at 120mph without the missfire occouring it was at the top of the 'n'.
could a split header tank cause the temperature to rise due to fall in pressure?
i was going to disconnect the water feed to the turbo to drop temps as i cant see a little bit of water cooling a glowing red lump of metal.
help!!!!!!!
Nov 1, 2015 06:53 PM
Fudgey
21
Sep 30, 2015 06:19 PM
