bleeding cooling system ???
Old Sep 8, 2005 | 06:26 PM
rsturbotim's Avatar
rsturbotim
Default bleeding cooling system ???
just wondering if anyone knows the best way to bleed the cooling system on the s2.mine was fine and didn't get hot in traffic then fitted a new fan switch and now it gets red hot.possible air lock or thermostat ?????? fan doesn't work automatically anymore either cheers
Old Sep 8, 2005 | 07:57 PM
Rick's Avatar
Rick
The system is self bleeding, and very rarely will u get an air lock. To get rid of air, run the car to temp with the header tank cap off, let it cool back down and replace.
Does it just get hot in traffic? If so, its faulty fan switch.
Old Sep 8, 2005 | 08:12 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
wots the best of way changing rad without getin a airlock??
(sorry to hijack thread)
Old Sep 8, 2005 | 09:10 PM
addiction's Avatar
addiction
as Rick said above,very rarely will you get an airlock,even when changing the rad!
Old Sep 8, 2005 | 10:28 PM
rsturbotim's Avatar
rsturbotim
thanks for that car is fine when driving but yes when stuck in traffic or even just crawling round town temps go through the roof up to the O on the temp gauge this is with the fan on as i had to wire it up to a switch but it doesn't make a shit of difference.
Old Sep 9, 2005 | 02:50 PM
Rick's Avatar
Rick
O on the gaguge is no problem at all in traffic mate.
Old Sep 9, 2005 | 03:46 PM
adamS2RST's Avatar
adamS2RST
Assuming it cools back down to a little over a 1/4 and the fan stops again.... it sounds like its getting hot and the fan is struggling to keep the car cool?
Old Sep 9, 2005 | 08:14 PM
rsturbotim's Avatar
rsturbotim
all sorted today thanks everyone must have had an airlock.
Old Sep 9, 2005 | 08:43 PM
NUTS RuS's Avatar
NUTS RuS
When re-filling and running upto temp for the first time put the interior heater control onto hot
Old Sep 14, 2011 | 08:43 PM
RSingabout's Avatar
RSingabout
Hiya guys,
My turbo orion is playing me up, my heater blower dont work but the pipes going in to the back of the heater matrix are hot, the fan kicks in and out, when the fan jumps in the coolant drops the when fan cut out the res fills slowly back up, my problem is that a few days ago my top hose adopted a small pin hole which as you can gather when pressure built up it sprayed all over the rad, with this the car was temping between the 0 and the R on the gadge. NOW with the hose replaced and everything working. pipes hot, fan working the temp gadge stays near the L and the A ( bottom of the gadge just of the blue. ive tryed bleeding the darn thing and everything still remains the same. Its doesnt smell and nothing out of the ordinary is acuring. what say you guys. gallon of petrol and a match comes to mind lol
Old Sep 14, 2011 | 10:16 PM
Rick's Avatar
Rick
First thing i'd do is replace the stat.
Old Sep 14, 2011 | 11:12 PM
RSingabout's Avatar
RSingabout
I've had the car about a month now and on buying it I was asured that it had new cambelt, filters and it had a new stat as the previeus owner did some head damage. But I will change stat as even a new one can fail
Thank you for your speedy reply and I will post the out come ...
Nov 1, 2015 06:53 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
A.t.p
Sep 29, 2015 05:04 PM
