how to remove fusebox???
how do i remove the fusebox from me S2 as its got water under it!!!!!!!!!!!! also is there anyway of preventing water from getting there????
cheers
daz
cheers
daz
www.ctuceilings.co.uk
Ok...
The top part where all the fuses are lifts up at the front. It is clipped in and comes away from the base which is screwwed down to the body with 2 screws. Unclipping the top gives you enough room to get a screwdriver in there to undo the screws then it just lifts out.
HTH
HTH
cheers fella.
any way of preventing water from getting in there as i dont wanna keep having to remove and replace it cause soon it`ll turn into something serious!!!!
They usually rust at the front of the hol;e where the bulkhead is and also the scuttle panel rots behind the windcreen rubber on the seam. Both areas will let water into the cabin.
