Boost problem
Old Apr 13, 2020 | 05:19 PM
Stu silloth's Avatar
Stu silloth
Default Boost problem
Could any one help me with my 1989 s2 turbo. It doesnt seem to pull as hard as i think it should in the higher gears.it feels like its holding back like a diesel with a blocked fuel filter if you know wat i mean.wen i ease off the throttle slighty it seems to help.a bit. Its been on rolling road and everything was ok but when the engine is pulling the car i can feel the problem. The enginge has been rebuilt.new fuel pump and filter.new plugs leads and distributor.
Old Apr 13, 2020 | 06:55 PM
gcfcos's Avatar
gcfcos
I had this and was spark plugs playing up. Also plug gaps I had to adjust on new plugs was also causing the same. Have you got a boost gauge fitted?
Old Apr 13, 2020 | 07:19 PM
Stu silloth
Ive had new plugs fitted.wat are the recomended plugs to use.its a cheap option to try.would ghe rolling road not of picked up on that? No i havent got boost gauge fitted. Its got a bailey dump valve. Ive read a few bad things about those. Ots got .31 actuator and a chipped ecu. Did yours pull better once plugs were set up right?
Old Apr 13, 2020 | 07:25 PM
Stu silloth
Car also has scorpion exhaust fitted.just read they arent the best either. In first gear you think this is gona be fast.but its not.it came of the rolling road at 144bhp. Not sure wat boost psi was.i just told the bloke i didnt want it to boost to high.
Thanasis
Nov 28, 2018 08:33 PM
GrantCraik
May 1, 2009 10:35 PM
LSD
Dec 28, 2006 06:18 PM
Geogr
Ford Focus RS
Nov 23, 2006 09:42 PM
