brake bias box
Old 16-10-2017, 08:18 PM
krolly
krolly's Avatar
Default brake bias box
hi, I've known my servo was on its way out since getting my car. went out in it Saturday and think over the winter it's going to be best to change it. I've looked at a brake bias box from burton power. apart from the two resivours needed is it just a case of removing the old one, carp the vacuum hose from the inlet and fitting the new box ? any help would be great
Old 17-10-2017, 09:38 PM
Piston Broke
Piston Broke's Avatar
Unless you have used one before mate I wouldn't get one. They are like braking on glass untill you get good heat in the pads and discs. I have one on mine but only due to using a getrag gearbox and space an issue. I have a servo and master that I removed that I may sell.
Old 18-10-2017, 11:53 AM
nigel b
nigel b's Avatar
nothing wrong with a good bias pedalbox
i have no issues using one
pad choice will affect how good or bad they work
Old 20-10-2017, 07:10 PM
krolly
krolly's Avatar
are they just a bolt in job then ? what do you do with the vac pipe off the Inlet mate ?
