What sort of power .
Old 16-01-2017, 12:37 PM
Rsmat
300+
Rsmat's Avatar
Default What sort of power .
Cvh on MFI .. k&n filter 3" stainless exhaust ..stage 2 turbo technics T3 .. pace rs500 style front mount cooler .group A coil ..Baileys breather kit and Greddy electronic boost controller.. what sort of power should it make as I'm off to MSD in Feb .
Many thanks Mat
Old 16-01-2017, 12:48 PM
Mad_Mat
New Owner
Mad_Mat's Avatar
I am going to have a punt at 180-190bhp. Enough to have some fun in a RST bud.
Old 16-01-2017, 12:54 PM
Billy_RS
Billy_RS's Avatar
170-180 bhp I reckon
Old 16-01-2017, 01:57 PM
TommysKeeper
TommysKeeper's Avatar
I'd expect it to be a bit lower say 175
Cheers, John
Old 16-01-2017, 04:26 PM
Rsmat
300+
Rsmat's Avatar
I wonder why the spec sheet for turbo says it will do 220 at 23psi ..I always run turbos flat out that's how I like them so hopefully see 200 ..:
Old 16-01-2017, 05:39 PM
Caddyshack
Caddyshack's Avatar
If you are going for max then swap out the rs500 cooler for as thick an airtec as you can get in there or better still the thickest spec r one that your wallet can handle.
Rsmat (16-01-2017)
Old 16-01-2017, 07:47 PM
colins2
colins2's Avatar
Default .
I'd say 170-180 I could never get enough fuel to run 21 psi on the MFI most I saw was 185 atw @16 psi
Old 16-01-2017, 07:52 PM
Rsmat
300+
Rsmat's Avatar
Mines thicker than the last spec r one I had hence I haven't swapped mate ..it's huge
Old 16-01-2017, 08:17 PM
Rsmat
300+
Rsmat's Avatar
My last one was over 200 with mfi but it had a T3.48 on and 22psi .back in 2000
Old 16-01-2017, 08:31 PM
Rsmat
300+
Rsmat's Avatar
Old 17-01-2017, 09:19 AM
colins2
colins2's Avatar
looks mint,
I have std compression stg3 big valve head stg 3 t3 cvh35k cam 3"mongoose k&n filter in std air box fully lightened bottom end inc fly and pressure plate and front mount ic.
Old 17-01-2017, 09:20 AM
colins2
colins2's Avatar
looks mint,
Old 17-01-2017, 06:25 PM
Rsmat
300+
Rsmat's Avatar
Well I hope it will do 200 ::
Old 18-01-2017, 01:47 PM
bassboy
bassboy's Avatar
TBH, I would say around 180-190hp, its difficult to say really, if its on a standard head and bottom end, I think you will need to keep ramping the boost up until either the turbo is on its limit, fuelling from the MFi is maxed out or the engine wont take any more boost efficiently....
I guess it depennds whos RR you use....im sure you could break 250hp if someone like Sabre Motorsports RR was used (as an example lol)
one thing to remember is MSD wont tune for numbers, they will tune so the car drives great and is reliable which can only be a good thing lol
Old 18-01-2017, 02:19 PM
Stu @ M Developments
PassionFords Creator
Stu @ M Developments's Avatar
Dont worry pal - You have plenty of time between now and then to lower your expectations to something more realistic.
Old 18-01-2017, 08:38 PM
Rsmat
300+
Rsmat's Avatar
^^^ real tears mate ..I'll have to bring a flask to comfort me .
Old 01-02-2017, 06:53 PM
essexRSTSouthend
essexRSTSouthend's Avatar
going by the stage 2 turbo you should run over 200bhp if your mfi is supplying the fuel for the boost. I hit 210bhp with standard turbo but the fuel was too lean at 20 something psi. boost was put down to 18 psi and made 195.9bhp on standard engine build. Obviously running a front mount cooler to keep heat down etc helped. so going by my figures i would expect yours easily be in the 200's mate. My dyno was done by power engineering. I'm not sure how accurate the dyno's are there.
Rsmat (01-02-2017)
