Roof clock wires
Old 06-09-2016, 09:40 AM
mentalasanything
mentalasanything's Avatar
Default Roof clock wires
Morning all,
Has anyone had luck threading new wires up to the roof clock?
Any thoughts on how to would be helpful!
Thanks,
Lee
Old 06-09-2016, 11:51 AM
nigel b
nigel b's Avatar
i use a stiff bit of wire or coat hanger
go from the top of the pillar down
Old 06-09-2016, 12:46 PM
haz87
haz87's Avatar
As above, stiff wire from the top then feed it all back up
Old 06-09-2016, 02:30 PM
RSmark84
RSmark84's Avatar
as above, I used to build cars in a factory and thats how its done when they're being built new.
Old 06-09-2016, 06:37 PM
mentalasanything
Cheers lads,
So I'll peel the headliner back to the A pillar and feed a thick wire down from there.
Thanks again!
Lee
Old 06-09-2016, 07:58 PM
slammedorion
slammedorion's Avatar
May need front screen out if your dropping the head lining?
I'd try just taking a post cover off and using the wire to fish it through
With the wire try putting string down the route first, then you can pull the loom up with it
Old 06-09-2016, 08:30 PM
mentalasanything
how are they removed though?
Lee
Old 06-09-2016, 08:58 PM
slammedorion
Door seal off around a post area, and pull carefully from under windscreen seal
You'll have to take the speaker out of the footwell too
Old 06-09-2016, 10:09 PM
nigel b
nigel b's Avatar
if you have a sunroof you can drop the headlining from there and it should work
faz_cossy
21-07-2016 12:28 AM
MMartin
Ford Fiesta
05-07-2016 09:35 AM
cossiejonjon
30-06-2016 04:47 PM
Hayley Fields Scrupps
12-06-2016 09:21 AM
rsturbo27
09-06-2016 10:10 PM
Quick Reply: Roof clock wires
