Rs turbo mfi conversion
Old Jun 3, 2016 | 10:49 PM
Dave West's Avatar
Dave West
Default Rs turbo mfi conversion
Hi all I'm new on here iv been looking bit can't find a conversion guide I'm sure their must be one somewhere anyone point me in the right direction. Cheers
Old Jun 3, 2016 | 11:47 PM
RSmark84's Avatar
RSmark84
Nope, there won't ever be an MFi conversion guide for an Escort RS turbo because it already exists from factory.
Old Jun 4, 2016 | 08:00 AM
colins2's Avatar
colins2
MFI to EFI?
Old Jun 4, 2016 | 07:04 PM
RSmark84's Avatar
RSmark84
Hmm, doubt it the M and E are nowhere near each other on a keyboard.
Old Jun 9, 2016 | 09:26 PM
Dave West's Avatar
Dave West
Lol OK I know they were done at the Factory but coz I'm building one myself I just wondered if anyone had put it on here what was done and parts used
Old Jun 10, 2016 | 09:00 AM
matthart's Avatar
matthart
You're confusing us all. All Escort RS Turbos were MFI from new, so you don't "convert" an RS Turbo to MFI, it already is!
Are you trying to convert a NON-RS Turbo into an RS Turbo? If so people would need to know what car you are starting with.
Old Jun 10, 2016 | 05:27 PM
RSmark84's Avatar
RSmark84
Christ im proper baffled now?
If you own a base model, then to convert it to an RS turbo would actually require you to buy an RS turbo.
Not sure what else to say, you appear to own an RS turbo judging by your reply... So can't help.
Old Jun 12, 2016 | 10:34 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
dude..you need a full loom from an erst. Use the full loom save the agro later.
Rest is self explanatory. Fit all parts from erst.
get on some friendly forums where people will help more instead of taking your lack of experience as a reason to hound you.
Old Jun 12, 2016 | 01:18 PM
Dave West's Avatar
Dave West
Hi sorry I wasn't very clear in what I was asking but yes it's a xr3I running on mfi and want to turbo it I'm in the process of building the engine just needed a bit of advice like do I used the xr inlet also iv read somewhere I need to change the metering head that's the reason I was asking if there was some sort of thread. Thanks for advice guys
Old Jun 12, 2016 | 01:27 PM
boeb's Avatar
boeb
If it's a budget project ad ditch going for mfi m8....find a mk4 g or h plate 3i for the loom..change some wires(be a guide somewhere)..source a fiesta rs turbo lump and Ecu....mfi is out of date and a pain in the ars..it was shit then and is shit now..it's only still used as peeps want orignal cars nowadays..not saying ofab/efi is the dogs bollox but it's better than mfi and if your budget building it will help in long run....unless this is not a budget build then ditch all above and go for summit more mappable lol
Old Jun 12, 2016 | 05:38 PM
mentalasanything's Avatar
mentalasanything
If your adamant on MFi, you need everything from an ERST:
Loom from an ERST
Both ECU's (fuel and ignition) from an ERST
Fuel metering unit
Sensors from an ERST
Head and inlet from an ERST
Cam for an ERST
Bottom end from an ERST
I did as Boeb suggested with a bit of a twist, but for EFi you'll need:
Loom from an EFi XR3i or FRST
ECU and sensors from an FRST
Head and inlet from any EFi 1.6 CVH
Injectors from an XR2i/FRST
Cam for an ERST
Bottom end from an FRST
And my sticky "How to" threat
MFi will cost you more than EFi to fit, expect to pay well over the odds for a known good metering unit if you can find one (your XR3i one is no good). As above, OFAB/OFAC aren't amazing, but a damn sight better than MFi and more scope to use more modern ECU's (e.g. OFAM) and injectors etc.
Lee
Old Jun 12, 2016 | 07:55 PM
Dave West's Avatar
Dave West
Thanks for that it was just the info I needed time to sit and have a good think. Cheers
Old Jun 13, 2016 | 03:21 PM
Karl @ FPT's Avatar
Karl @ FPT
Always a pleasure!
What's your budget mate?
As your going to a lot of trouble starting from scratch I would save some future trouble an go EFI from the start, not old Ford EFI though if you can help it, often just as troublesome as MFI these days.
Old Jun 21, 2016 | 03:29 PM
XR2's Avatar
XR2
I heard that a thousand times in the last 20 years. Mostly because people don't understand how the Bosch K-Jetronic works and therefore were overchallenged when something went wrong (what seldom happened) or they were trying to get power out of them hillbilly-style.
The K- and KE-Jetronic (KE was available also as N/A with 90 hp) CVH units were VERY reliable, fuel consumption and power output was better than in EFI cars, especially N/A XR3i. Reconditioning of the mechanical parts can be done quite easily, as far as you know what you're doing. Bosch offers ALL parts and all type of work for the K(E) via "Bosch Automotive Traidition". Only tricky part could be the Ford ESC-II module, but these usually don't cause problems.
90s Ford EFI... new parts are rare or not available and when you face an electronic problem you're totally lost today with these units unless you know someone who kept all of the old diagnostic tools etc.
And... I don't understand why Porsche, Ferrari, Audi, VW, BMW, Mercedes-Benz, Ford and many more used the K-Jetronic for ages when it was shit???
shanek2041
Fiesta RS1800/RS Turbo
Mar 6, 2021 07:06 PM
L1AM_RS
Jun 1, 2016 09:52 PM
shanek2041
May 28, 2016 03:02 PM
TrevCos
May 26, 2016 04:40 PM
TrevCos
May 23, 2016 11:13 AM
