Full geometry settings needed.
Old Mar 16, 2016 | 06:30 PM
muz's Avatar
muz
Wye Valley Hardcore
Default Full geometry settings needed.
What's are people's tried and tested 4 wheel alignment settings?
Camber, caster and toe for front and rear.
These settings seem to be kicking about, but has anyone got and experience with them?
1.5 degrees negative camber.
0 degrees 30 minutes toe IN.
That is the Grp A RS Turbo (Series 1) settings which will make it more controlable on a straights but the turn in won't be as easy or wanting.
If you want to try these settings for a tight turn / track, set the toe to this..
0 degrees 30 minutes toe OUT.
That will make it more nervous in a straight but down the lanes, it will turn in really sharp.
In case you are having a 4 wheel alignment here are the other recommeded settings..
2 1/2 degrees positive castor.
Rear.
0 degrees 30 minutes toe in.
1 1/2 to 2 degrees negative camber
Old Mar 16, 2016 | 09:13 PM
nigel b's Avatar
nigel b
im running 2.5 degrees camber front
1-1.5ish rear
castor is 4 degrees but you wont get that
mine is set very slightly toe out on the front and very slight toe in on the rear
you also have corner weight balancing
Old Mar 17, 2016 | 01:22 PM
gus's Avatar
gus
Yeah mine is very similar to Nigel's.
Not as low as yours tho nice a ������
Old Mar 17, 2016 | 05:23 PM
muz's Avatar
muz
Wye Valley Hardcore
Cheers, lads. I'll give it a go. Yeah, it could do with corner weighting as well.
Old Mar 17, 2016 | 07:29 PM
nigel b's Avatar
nigel b
dont set the ride height too low,you might get a driveshaft catching
Old Mar 17, 2016 | 11:15 PM
muz's Avatar
muz
Wye Valley Hardcore
Is mine A touch on the low side then, you reckon?
Old Mar 18, 2016 | 01:01 PM
nigel b's Avatar
nigel b
looks about right height
Old Mar 18, 2016 | 01:09 PM
haz87's Avatar
haz87
Camber and toe pretty much the same as Nigels for me also.
Old Mar 19, 2016 | 08:10 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Muz the settings are on the forum mate. 3 different settings to choose from.
Old Mar 19, 2016 | 07:18 PM
gus's Avatar
gus
Mines quite similar to Nigel's and I found it quite neutral so a good base to start from
Think a lot will depend on how you like to drive
Corner weighting is a must IMO
Old Dec 4, 2019 | 09:53 AM
catespec's Avatar
catespec
Great work on your Ford Focus.
Russ Payne
18
May 6, 2017 02:09 PM
4parajon
Mar 21, 2016 07:09 AM
Cosnada
Mar 14, 2016 06:46 PM
SmudgerByName
Mar 13, 2016 04:30 PM
Alloy wheels and ICE for sale
Mar 13, 2016 08:57 AM
